During the process of choosing geometry to run a rough contour or flowline tool path I get the following message:
"check and drive stock to leave are identical, you may wish to adjust check stock by plus or minus cut tolerance for crisper tool motion near external sharp corners formed by check and drive geometry"
How do you adjust the check stock tolerances at this point in the process?
