586,102 active members*
2,394 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > what endmills for wood?
    Jan 2009
    396
    Can I use HSS endmills for machining wood? Or do I need a special material endmills designed just for wood?
    I could be doing wrong, but so far quite successful use HSS 45-55 mills processing different tropical woods like mahagony, sapely, etc.
    You can get them for small $ on Ebay for ~ 5.50 US per 3mm mill, which looks to be ok for me ;-)
    Jul 2009
    272
    Carbide tooling would be preffered by any woodworker.
    http://www.onsrud.com/xdoc/wood
    This will get you started, you do not need to buy that brand.
    Jan 2009
    396
    Can I use carbide for aluminum also or just strictly for wood?
    Yes, you can use carbide for aluminum too.
  1. Endmills okay for wood?
    By phantomcow2 in forum DIY CNC Router Table Machines
    Last Post: 09-02-2010, 02:55 PM
  2. Can I get some advice on what endmills to get first?
    By slashmaster in forum MetalWork Discussion
    Last Post: 03-29-2009, 06:23 AM
  3. Which Endmills?!
    By firestorm1284 in forum Benchtop Machines
    Last Post: 02-26-2009, 04:59 PM
  4. Working with Endmills
    By Burn in forum Benchtop Machines
    Last Post: 05-16-2006, 08:40 PM
  5. Anyone used these endmills?
    By Cold Fusion in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2004, 05:16 AM
