586,076 active members*
3,917 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Bosch colt router Dimension / Measurements Please :)
Results 1 to 16 of 16
    Jun 2009
    231
    I have a new Bosh Colt on it way and was wondering if anyone can share diameter measurement?
    I am building my table and would like to cut the holder for it but don't have the physical router just yet.
    (nuts)
    Oct 2009
    118
    Could someone please post this measurement? I think it is 2-1/2 inches in diameter.
    Regards,
    Ken
    Jun 2009
    231
    So I went in a store and pulled the base off the display router. With a VERY rough measurement I'm getting around 2 13/16" - 2 7/8". That's all I needed to know. I'll cut for it when it arrives.
    Oct 2008
    1147
    Once you get it in and and are able to get an accurate measurement, please post the dimensions. You may help someone down the road.
    Jun 2008
    203
    I would be interested too. I posted the 3D model I made of of my Bosch router. I am currently designing a new CNC around the Colt. If anyone had the critical dimensions I would really appreciate it!!
    My 3D bosch file...
    http://www.grunblau.com/downloadsbmo.htm
    Jun 2009
    231
    Quote Originally Posted by Grunblau View Post
    My 3D bosch file...
    I received it on Christmas eve~!! Haven't opened it yet. I will get the basic measurements and post here soon. Does anyone need anything other then the diameter?
    thanks
    Oct 2008
    1147
    The mounting surface height would be a good idea too
    Jun 2009
    231
    Ok here's what I got. All in "mm"
    Easier to post pics then to describe!
    FYI, If someone makes a working file using these dimensions, please be kind and post it here.
    **with base**
ID:	96129Click image for larger version.
    **Base OFF** / rear grip height
ID:	96131Click image for larger version.
    *Front grip height / Base to Col
ID:	96133Click image for larger version.
ID:	96135Click image for larger version.
    Jun 2009
    231
    BTW, this is one nice router. Quite and runs MUCH better then anticipated. Great buy. I may get a little crazy and use it as a trim router on my machine tonight! LOL
    Jun 2009
    231
    Thanks Grunblau for the DIY cable track. I was just about to try and work up something similar when my machine was finished. Excellent. Have you cut this yet? Have a pic? Are these glued when complete?
    May 2009
    Quote Originally Posted by JohnnyVegas View Post
    Here we go...
    Thanks so MUCH for sharing the dimensions, this was very usefull, so I have made a mount for the colt.
    If you need the 3d Model, just go to Google Sketchup 3D Warehouse, I have shared the model there "Bosch Colt Mount"
    Attached Thumbnails Attached Thumbnails boschcolt_01.jpg   boschcolt_02.jpg   boschcolt_03.jpg   boschcolt_04.jpg
    Jul 2009
    140
    I don't know if this is a reasonable alternative or not, but K2 in the US makes a very good clamping holder for the Bosch Colt...buy one of those and devote your time elsewhere, perhaps?
    It would guarantee you a working clamp, no need to worry about tolerances, fit, etc.
    ck
    Jul 2010
    Even the thread is old, but it really help me alot at my current process. Thank you too much for your sharing!
    I'm a bit of worried about the heigh adjustment of Z axis. After assembling Z axis, what kind of calibration type I need to do for this step? Hope someone give me a hand about this...
    Btw, thank you very much guys!
    May 2013
    16
    So I stumbled upon this thread because I was looking for a 3D model of the Bosch colt router. I didn't find one so I made one instead. You can check it out over at Grabcad. I have pretty much all of the important dimensions to within about 0.005". Hope this helps someone!
    Bosch COLT 1HP
    Oct 2010
    30
    I think the 37th dimple on the hand hand grip might be a little off
    Wow that took a couple of minutes to do.
    Wish I would have had this about 8 months ago!
    Nice job.
    May 2013
    16
    Thanks! Yeah I guess it wasnt enough to just model in the critical portions.... I had to make the sucker look nice
  1. Bosch Colt router and 1/8" collet
    By alecu7 in forum DIY CNC Router Table Machines
    Last Post: 03-15-2010, 01:41 AM
  2. Colt Bosch Spindle
    By John Bear Ross in forum Taig Mills / Lathes
    Last Post: 02-08-2010, 06:30 PM
  3. Replies: 0
    Last Post: 09-03-2009, 02:50 AM
  4. Colt™ Variable-speed Palm Router Kit
    By justCNCit in forum DIY CNC Router Table Machines
    Last Post: 02-16-2009, 07:14 AM
  5. Gerber Dimension 200E CNC Router with engraving head
    By vipers95 in forum Commercial CNC Wood Routers
    Last Post: 02-15-2009, 03:08 AM
