Im looking for suggestions on what to use for a spindle and motor. Its looking strongly like Im going to probably build a CNC from scratch.
I think my chances are pretty good on being able to score linear bearing rails and ball screws at work, so I think it would be better for me to build my own instead of spending the money on a manual system and converting it.
So b/c of that, Im going to have to find a spindle and a motor to use in my build. I suppose its possible that I might be able to get one from work too, but Im pretty sure that anything they might have at work, would be extreme overkill and just physically too large to work w/ what I would want or need.
The vast majority of the work on the machine would probably be aluminum w/ occasional brass & copper. It might see an occasional steel job, but that would be rare, b/c of what I have in mind for the machine.
Milling, Drilling and Tapping obviously would be the operations run on the machine, so that would need to be kept in mind. I dont imagine I'd need more than 2-3k RPM's since most of the tooling is likely to be smaller, 1/2" mills and smaller. Occasionally might see larger boring using boring bars and such, but I wouldnt expect it to happen often at all.
