586,103 active members*
3,557 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Flat surfacing a timber burl
    Oct 2008
    8
    I have a really nice timber burl about 800mm x 400mm oval (roughly) and I would like to engrave a sign on it. Unfortunately, the surface is uneven (not flat). Is there an easy way of producing a flat surface using Vcarve Pro? or do I need to do it with manual passes a little at a time? If you have faced this problem before, could you let me know how you solved it please. Cheers .. Oncoarse.
    Jul 2009
    272
    Yes it can be done by creating pocket covering entire area to be flatten using biggest endmill you have. I use 30mm mortise bit same that i use to flycut my spoilboard. Flip and mill other side if needed.
  1. Replies: 9
    Last Post: 05-23-2015, 06:31 AM
  2. Need help surfacing!!!
    By kbeard in forum Musical Instrument Design and Construction
    Last Post: 06-08-2010, 10:38 PM
  3. Lathe Bed: how flat is flat enough?
    By Donkey Hotey in forum Haas Lathes
    Last Post: 05-17-2010, 08:35 PM
  4. 100% flat table for flat bed lamination
    By Bernhardsen in forum Printing, Scanners, Vinyl cutting and Plotters
    Last Post: 08-24-2008, 02:31 PM
  5. surfacing help
    By lt paul in forum Rhino 3D
    Last Post: 07-16-2004, 03:48 PM
