586,076 active members*
3,822 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Allen B Ultra 100 drives experts?
Results 1 to 6 of 6
    Aug 2005
    828
    Any one know how to make a custom motor profiles in the Ultramaster software? I want to try running a Mitsubishi motor but need to change the encoder count # and hall offsets but the software won't let me. It says in the manual that it can be done but doesn't say how exactly....
    The drive runs allen b motors no problem.
    Dennis
    24221
    I believe these are made by ElectroCraft? The same as the BRU series?
    I have been trying to reconfigure the E.C. style and even contacted ElectroCraft and they say they don't support them anymore due to being obsolete.
    As far as I can tell so far, the prom has to be reprogrammed or changed.
    What is the AB software you have? As it should work on the E.C. version also.
    Also the encoder input requires a commutation input pin which from what I gather only applies to A.B. or E.C. motors?
    Do you have the manual in PDF, by the way? I would like to get a copy if it is different from the EC.
    Al.
    Albert E.
    Aug 2005
    828
    I have the Giddings & Lewis software DSMPro it is exactly the same as the UltraMaster have it also. I have both A B 1398 and Electrocraft BRU drives it's all the same just different stickers on them.
    In the AB manual it says the motor profile .MTR its a binary file that is made by Ultramaster software but there is no option to make it.
    PM me i'll send you more info...
    Dennis
    Jun 2003
    866
    I don't think there are any experts here because I didn't even get a "duh" response to my thread about communications. I've never tried to do this, but I saw something in the Giddings literature about the "ABS" track. But maybe it was when they went to the next series you needed hall tracks and the older motors didn't have it. I'm just posting this as a "duh" response so that you know the system is working.
    Aug 2007
    558
    Quote Originally Posted by DennisCNC View Post
    Hi DennisCNC,
    To make custom motor profiles you need to use Ultra Master advanced. I'm sorry I don't recall how to get into the advanced version, but it is supposed to be in the Ultramaster help menu. From memory, I think you start the software using a command line parameter, but it's been a while and I'm VERY rusty on this, so please don't hold me to that!
    Al.
    Hi Al, is it the manual for the AB Ultra 100 you're after, or the Electrocraft BRU series? The Ultra 100 series manual is top of this list.
    Best regards,
    Jason
    24221
    It looks like the BRU E.C. are different (physically anyway) than the A.B. drives.
    From what I see so far, the motors have the absolute pulse in order to initialize sinusoidal commutation off the encoder differential pulses.
    This rules out the use of BLDC motors or any AC motor that does not have the initialize pulse.
    Al.
    Albert E.
  1. Allen Bradley Ultra 100 drive with non Allen motor?
    By DennisCNC in forum Servo Motors / Drives
    Last Post: 10-30-2009, 01:44 AM
  2. Surplus Allen Bradley drives
    By controlfreaked in forum Servo Motors / Drives
    Last Post: 06-28-2009, 10:48 PM
  3. Allen Bradley Ultra 1500 drive
    By beernuts in forum Want To Buy...Need help!
    Last Post: 09-09-2008, 02:56 PM
  4. Ultra PDM drives and motors
    By Hood in forum Servo Motors / Drives
    Last Post: 03-13-2008, 10:01 PM
  5. Allen Bradley Ultra 1500 Drive Connectors
    By Kookaburra in forum Servo Motors / Drives
    Last Post: 07-19-2005, 02:58 AM
