586,608 active members*
3,441 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Simplist up down z for mobile gauntry
Results 1 to 6 of 6
    May 2008
    10
    Hello,
    I am in the process of researching how to make my own mobile gauntry cnc plotter. I am trying to figure out what is the simplest up/down Z axis solution. I found a lot of complex designs where the Z positioning has a large travel through a a lead screw, but I need something really simple. Could someone point me to something like a plotter?
    Thanks,
    Frank
    Jan 2008
    853
    Hi Frank
    If the plotter is always writing on a single XY plane, then any mechanism to remove the pen tip from the plane should work, no? What about a simple $10 PWM servo (the type that RC modelers and robotics hobby folks use) that would swing the pen away from the writing plane? A solenoid may work, bu the travel is usually very short, and they would heat up when energized for long periods of time.
    Cheers!
    Paul Rowntree
    Apr 2007
    8082
    Quote Originally Posted by PaulRowntree View Post
    Hi Frank
    Cheers!
    Paul Rowntree
    The solenoid should be energized only when the drawing pen is down. A light tension spring should be used to retract the pen when not drawing. The spring should also apply a small amount preload to the pen while drawing so that during small irregularities in the drawing surface the pen does not skip.
    CarveOne
    CarveOne
    http://www.carveonecncwoodcraft.com
    May 2008
    10
    Thanks for your responses.
    Can a solenoid system be made out of a big mechanical relay dissasembled and used for the motion? Is there a simpler way to make a solenoid mechanism?
    I will look into the servos too.
    Apr 2007
    8082
    Quote Originally Posted by transfrank View Post
    Most mechanical relays have a fixed metal core inside the coil and a metal plate is attracted to the core when voltage is applied to the coil. The contacts move with the metal plate. They would not be useful as a solenoid.
    Tubular solenoids come in push or pull types. An R/C servo will work but you need a way to operate it. The simplest way I know of is to use an R/C servo tester that can be purchased. No transmitter or receiver is necessary that way.
    The pen holder can have a ball point pen spring inside to provide the preload function. I made a spring loaded BIC pen holder in one of the threads in this forum sometime during 2009. It was just a K&S brass tube that was sized to fit a BIC ballpoint pen.
    CarveOne
    CarveOne
    Jan 2008
    853
    Parallax Inc. (www.parallax.com) sells several microcontrolers that can provide PWM outputs to drive small servos. I have used the Propeller Protoboard to drive them... software is free via the Object Exchange. Cost would be ~$55 for controller, power supply, servo.
    Cheers!
    pr
  1. dnc & windows mobile
    By chrisryn in forum DNC Problems and Solutions
    Last Post: 10-25-2021, 01:00 PM
  2. Mobile base for IH Mill
    By ProGunOne in forum Charter Oak Automation Support Forum
    Last Post: 01-16-2008, 11:03 PM
  3. Weight of mobile parts
    By Cherezov Oleg in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2007, 11:35 AM
  4. Mobile base for the IH: any ideas?
    By deaeni in forum Charter Oak Automation Support Forum
    Last Post: 07-30-2006, 02:25 PM
  5. Zen, CNC, and Mobile Robots
    By ToyMaker in forum RC Robotics and Autonomous Robots
    Last Post: 02-06-2005, 11:39 PM
