Smitty, what format do the arcs have to be written in for Turbocnc?
Details we'd need to know:
Is your main program in G90 absolute mode? If so, then are the arc centers supposed to be in absolute coordinates as well, or incremental (check your documentation).
What if your main program is in G91 Incremental mode? Presumably all coordinates would be incremental under these circumstances.
Does Turbocnc accept workpiece diameter values for X movements, or radius only?
Because of all these different parameters, it would only confuse you for someone to send you a file that is not written in a method compatible with your controller software requirements.
Doesn't anyone else out there use Turbocnc for lathe, or what? Step up to the plate here, you're up
