586,072 active members*
4,472 visitors online*
    Dec 2009
    12
    Photos of complex millings.
    Please show off photos of your complex parts, I am trying to determine the capabilities of mills in the size of the Novakon MN-135 or equivalent cnc mills.
    Thanks JL
    Mar 2004
    1661
    Complex millings can be done with any machine. The complexity is directly related to the CAM-software used and the skills of the CAM-technician/machinist, not the machine.
    What you should look for is the speed available and how rigid the machine is.
    Oct 2005
    278
    you should be on youtube or .......
    just being polite.
    Finally CHIPS you can have as much as you can without the doc. complainting about your cholesterol.
    Dec 2009
    8
    Quote Originally Posted by svenakela View Post
    X2... Well said!
    Dec 2009
    12
    Svenakela,
    I have a hard time believing that the NM-135 can do the same complexity and detail as the Roland MDX-40A, Although I cannot afford a Roland at this time and it is probably capable of higher detail than I want. It may seem common sense to you what the capabilities are, it is not obvious to me. I have basic milling experience. I would have thought that people would be interested in showing some neat projects.
    Thanks any way....
  1. Calculating deflection on complex geometries
    By Ed from NY in forum Mechanical Calculations/Engineering Design
    Last Post: 08-12-2009, 01:24 PM
  2. 6061 just a little complex
    By mc-motorsports in forum Employment Opportunity
    Last Post: 09-07-2008, 08:59 AM
  3. complex 3d milling
    By ppsi in forum Dolphin CAD/CAM
    Last Post: 11-22-2007, 02:20 AM
  4. Complex sign design
    By maxxgraphix in forum G-Code Programing
    Last Post: 03-26-2005, 03:34 AM
  5. complex patterns
    By drc in forum Uncategorised CAM Discussion
    Last Post: 09-22-2003, 11:13 AM
