586,069 active members*
3,332 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Miyano fanuc 10t threading problem
    Dec 2007
    48
    i have a miyano fanuc 10t controller im trying to tap 1/2 -14 npt using a g32 tapping cycle when it starts tapping the chuck just about comes to a stop.turning 400 rpms .071 per rev depth 1.06 can someone help me with why the chuck wont stay at 400 all the way through. thanks.
    Feb 2006
    992
    Post your program here so we can help you. I suspect you have G96 instead G97
    The best way to learn is trial error.
    Nov 2006
    418
    Also, what HP does your machine have behind the spindle? I haven't run the numbers but I would say you will need atleast a 10HP spindle motor.
    Some smaller lathes don't have enough juice to do that size of NPT tap - especially after many years of use and increasing frictional power losses.
  1. Miyano BNC-34C turret problem!!!
    By rai in forum Fanuc
    Last Post: 05-03-2016, 03:01 PM
  2. Replies: 1
    Last Post: 04-15-2009, 05:55 AM
  3. Threading problem on Miyano
    By Mark18969 in forum MetalWork Discussion
    Last Post: 11-10-2008, 02:28 PM
  4. Miyano T5V-25 problem.
    By tac8357 in forum DNC Problems and Solutions
    Last Post: 02-02-2008, 03:42 AM
  5. Miyano parameter Problem
    By AFX in forum Fanuc
    Last Post: 02-01-2007, 08:28 AM
