586,112 active members*
3,070 visitors online*
IndustryArena Forum > CAM Software > Mastercam > COMMUNICATIONS SETTINGS NOT SAVED
    Sep 2007
    92
    I am running X3 and when I go to communicate with the machine to send a program, the baud rate, stop bits etc. are all screwed up and I have to reset them every darn time, I have gone into the machine def, and the control def via the machine def, all settings look good when viewed but if I close out of MCX and open a new session, back to the wrong settings even though the machine def still looks correct??? any clue to what is going on? thanks in advance
    Dec 2008
    3109
    What software are you using to communicate with ?
    and how ? RS232 ?
    In Cimco, it doesn't use the mastercam settings, I'm guessing other software would be the same.
    The Xfer settings would need to be done thru the actual software set-up area, something like- create a macine or contoller profile, set your baud, blah blah etc and then save
    You open the NC-file with the Xfer software, select a profile, then, "Send to Machine", go to the machine and then "Read" that file into the control.
    This is a basic procedure to send the entire file, it may alter slightly for different machines
    DNC is a similar procedure, but the machine must be DNC capable before going into this area
    Sep 2007
    92
    thanks superman,
    there are 3 choices when i click the little communicate button on MCX, they are legacy, mastercam and cimcodnc, I never thought to change it because the lathe guy who gave me a quick heads up before he quit never said anything about that, just commented how mastercam never seems to remember settings, do you recommend that i try the cimco? or is mastercam just as good. we do communicate throught the rs-232 port but rarely do we drip feed programs. thanks
    Dec 2008
    3109
    Try to get the transfer program to operate without running mastercam.
    ( I suggest using the software that you have set to open the posted files in the editor )( you post the files, it opens in the editor, do some checks etc, select a machine profile, then send to that machine. )
    We use OneCNC, but they all tend to operate along the same lines
    some use seperate recieve and send settings
    Have a simple test program in the control and upload to the PC first as the controllers sometime add code to the files during transfers, ie a filename or % on the first line and a % on the last. And it does make it easier.
    Adjust the PC settings to suit the control settings then you will know what is needed in the file when sending to the control.
    When you have set the PC to recieve files, then ttry sending that file back to the control
  1. Replies: 9
    Last Post: 11-17-2010, 02:20 PM
  2. Demo Mode saved drawing
    By cncpilot in forum BobCad-Cam
    Last Post: 10-25-2009, 06:03 AM
  3. BCC v22 Speed/Feeds corrupted if file saved without post
    By brooklynmetal in forum BobCad-Cam
    Last Post: 03-25-2008, 02:33 PM
  4. port and pin settings not saved?
    By Block16 in forum Mach Mill
    Last Post: 09-26-2007, 02:13 PM
  5. NcPlot could have saved my butt
    By Karl_T in forum NCPlot G-Code editor / backplotter
    Last Post: 08-30-2006, 12:51 AM
