586,082 active members*
3,732 visitors online*
    Apr 2009
    4
    Smile Logitrol CNC Systems
    Hi All
    Very new member here looking for a little guidance. I have read the comments about retrofit but I am in the position of already owning a BP. So I am looking to retrofit. I have come across the above system that seems ideal but at a real bargain price. Can anyone comment on the quality of the logitrol systems? I see it uses Mach 3 software which seems ideal for my use (I want to cheat and load .dwg direct) and seems to be respected by all.
    Any comments gratefully received!!
    Many thanks and Happy New Year to all!!
    Jan 2010
    Logitrol
    This is my first post here goes.
    I ordered one of the Logitrol CNC 4 axis Servo kits with 1200 oz/in servos. When i received it I took it apart to find 4 Gecko G320s, a BOB, and power supply. After months of reading here on the Zone and playing with my kit if I were to do it again I would build it myself for 1/2 of the cost with the same parts. It is a good kit done nicely and works great and for beginners like me at the time, sure makes it easy. I am putting it on a boss 8 I am in the process of retrofitting. So far all I have done is hook it all up with the motors tuned and running on my den floor playing with Mach while I am building the adapter plates and shafts for the motors and going through the mill from top to bottom.
  1. Logitrol Pendant and users
    By gunlocators in forum CNC Machine Related Electronics
    Last Post: 11-03-2008, 03:56 AM
  2. any experience with logitrol pendant?
    By scudzuki in forum Benchtop Machines
    Last Post: 10-09-2008, 03:27 AM
  3. logitrol systems anyone run there controls
    By margay20 in forum Mechanical Calculations/Engineering Design
    Last Post: 01-06-2007, 08:21 PM
  4. logitrol systems driver
    By ultronics in forum European Club House
    Last Post: 11-18-2006, 03:04 PM
  5. Any one use logitrol system
    By BUD B in forum Uncategorised CAM Discussion
    Last Post: 02-16-2006, 12:06 AM
