586,112 active members*
3,251 visitors online*
    Feb 2006
    174
    MPG2 pendant and Smoothstepper
    Hello, is there anyone that has this combination up and running, and would like to share how?
    Can I follow the instructions here: http://cnc4pc.com/Tech_Docs/guide_fo..._over_LPT2.htm , and use their brain?
    I am using the C25 SS connecting board.
    Lars
    Feb 2006
    174
    I managed to get it working after an whole evening of fiddling, by using a combination of pc4cnc instructions and http://www.markusmechatronics.com/Handrad_HowTo.html
    I had to assign the right hotkeys and run the brain: Axis_JogRes_Selector.brn
    Also had to wire the switch common wire to ground, not to +5v.
    Lars
    Aug 2007
    4
    Hello Lars,
    I have the same pendant and the ESS plugged into the C25 bob, like you. Having a hell of a time with it. The Brain from CNC4PC is old, and doesn't seem to work. Could you share the Brain and your settings with me? My email address is: [email protected]. The guide is confusing, and Arturo doesn't want to work with me any more. I also have an issue with the C41 spindle control board from him. Is that what you are using also?
    Mike
  1. G540 and SmoothStepper
    By Nzoldun in forum Gecko Drives
    Last Post: 07-31-2010, 05:22 PM
  2. G540 and Smoothstepper
    By escott76 in forum Benchtop Machines
    Last Post: 08-28-2009, 08:24 PM
  3. Anyone tried a Smoothstepper?
    By Ranscon in forum CNC Machine Related Electronics
    Last Post: 03-07-2009, 07:37 PM
  4. SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 09:09 PM
  5. SmoothStepper Now available in Australia.
    By phomann in forum News Announcements
    Last Post: 06-13-2008, 02:24 AM
