586,052 active members*
4,360 visitors online*
Results 1 to 13 of 13
    Sep 2009
    Anybody here use Vectric VCarve?
    I need to know if it is possible to cut the arm and tummy contour with VCarve or Cut 3D. How do you guys accomplish this? Thanks McGuire
    Apr 2009
    149
    Hi~
    I use VCarvePro, but what is an "arm and tummy contour"?
    May 2010
    you can do it with a flute cut if I remember correctly. I don't like that type of cut myself and prefer to see the smoother transitions of a surface loft in SolidWorks.
    Aug 2009
    19
    is it possible with Cut3D, it would even be better to use VCarve with Cut3D, and import the the Cut3D toolpaths into Vcarve and use Vcarve for pocketing pickup routes, neck pockets and profiling the body, I happen to be working on getting this process down lately, my friend asked me to make him a Ibanez type guitar but with a few modifications so I have been learning the process this last week.. if you or anyone is interested I may be able to make a tutorial on how to do this.. First I'd better cut this guitar and make sure the process works as good as its looking right though..
    :rainfro:
    Attached Thumbnails Attached Thumbnails ibanezbackwithcontour.jpg   ibanezfrontwithcontour.jpg
    May 2010
    Quote Originally Posted by konalure View Post
    :rainfro:
    how are you indexing it to cut both sides?
    Aug 2009
    19
    there are dowel pin holes to reference the piece. the holes will first be cut in a spoilboard ( that does not move at all during the whole process and is the base for the work to sit on..), then in the wood, then the wood is flipped onto these holes and attatched with dowels..., then a second set of holes in drilled for the flip..I did not include them in the previews I posted but they will align the guitar when it its fliped to carve the 2 sides.. getting the wood all planed evenly will be critical for this to work properly.. flipping the vectors and generating the toolpaths in the software can be a bit tricky ( to keep everything aligned) , you have to be sure the dowel pin holes are in the right place.. I learned this the hard way on another project.
    :rainfro:
    Aug 2009
    19
    I cut that guitar body the other day.. came out a lot nicer than I thought it would.. Next one I cut I'll document it better and make a tutorial on it.. need to get some screenshot software to capture the vcarve/cut3d stuff to explain how I do it.. anyone know some good free software to capture screens?
    If you want to make video tutorials, watch this.
    [nomedia="http://www.youtube.com/watch?v=DIm4SLndHU4&feature=player_embedded"]YouTube- Tutorial for making tutorials. Camstudio 1280 x 720, H.264 codec, perfect quality, 2meg per minute.[/nomedia]
    Apr 2009
    149
    Most graphic programs can capture screen images. Your keyboard should have a key titled "Print Screen". This will make a bitmap image of your entire screen and save it to the clip board. In your graphics program just Paste or Paste As New Image, then edit the file to what you need.
    Nice guitar. I am starting to design guitars in VCarvePro, also, and find it much easier and less time consuming than modeling in Solidworks and transferring to Mastercam for the gcode. Of course, I am interested in seeing your tutorial on creating the contours.
    Apr 2009
    144
    Looks good man! Would love to see a tutorial of you do this again! Especially if you did it all with vcarve/cut3d.
    No radiused edge though? or are you going to use a plain router for that?
    Planning on making a neck or did you size it to use a stewmac or similar neck?
    JGRO Complete - G540, 380oz Nema23s, 1/2-10 ACME, 30"x14", Craftsman router
    Joes 4x4 R&P in progress
    Apr 2009
    149
    Quote Originally Posted by dustin1706 View Post
    I find it quicker to just use a round-over bit on my table router for the edges, and then a set of flat and round files to cut the neck contours for easier fretboard access.
    I've only made trial cuts for guitar bodies (I've done 6 so far with scrap material) and I am working on my first neck. When I have a process down for completing a usable body, I'll post a quick tutorial on my process.
    In the mean time, I'm watching these posts for ideas on improving my skills!
    Jul 2007
    1602
    http://www.mirekw.com/winfreeware/mwsnap.html works pretty well. It isn't fancy but has enough features to do the job.
    bob
    Aug 2009
    19
    I should note that I also used Rhino to make the contours for that example I posted.. Cut3d will only generate the toolpaths for the contours, not create them..
    I find it much faster to just use the router table with a roundover bit for the radiused edge... I plan on making a neck for that body, I've got the modeling pretty much done, just need to get down to the wood store and get some decent maple. working on a tutorial now of the whole Rhino-Cut3d-Vcarve process.. , I'll post it here when I finish it hopfully this week.. (nuts)
  1. Marvels of Vectric VCarve Pro- Free Interior Decoration master Pieces
    By Khalid in forum PhotoVCarve and VCarve Pro
    Last Post: 03-31-2013, 03:08 PM
  2. Vectric-PPs for USBCNC
    By elses in forum Post Processors
    Last Post: 11-04-2009, 11:24 PM
  3. WTB Vectric
    By tdnp in forum Vectric
    Last Post: 03-22-2009, 04:43 PM
  4. Vectric Vcarve Pro 4.0 Tips & Tricks
    By Switcher in forum PhotoVCarve and VCarve Pro
    Last Post: 01-07-2008, 12:31 AM
  5. Replies: 1
    Last Post: 11-15-2007, 01:51 PM
