586,108 active members*
3,269 visitors online*
Results 1 to 16 of 16
    ftec Guest
    Homing with index
    Where can I find enough information to understand the concept of homing with index and implementing it? Drives are VSD-A. Thanks.
    Sep 2004
    1207
    There are only two parameters that sets homing with index:
    -Use index pulse for homing: disabled, positive edge or negative edge
    -Index search direction: positive or negative
    So first define wich polarity pulse the encoder is outputting. In 99% cases its positive. Then just choose rotating direction where drive starts looking for index. If you choose positive, then drive will rotate motor to positive direction and stops at index pulse.
    You might also want to use index with home switch or hard stop homing feature to make drive stop on correct revolution. You may also adjust homing speed from Trajectory planner page.
    Its safe to experiment with settings if you set torque limits so low that hitting machine ends won't damage anything.
    ftec Guest
    Ok, so one index pulse per rev. Can you tell how accurate this homing is? With rotational axis I don't feel like trusting external homing switches to get the angles right.
    So, if I don't want to use homing switches at all I must power the machine off so that all motors are within the same revolution where I want them to be homed when power is turned on. Perhaps run them, say, a half rev away from the index home before turning the power off?
    When power is turned on the homing obviously will start for all axis simultaneously. Can I control the starting of the homing with the Disable input (we have a separate Disable/Enable switch for each axis)?
    If one axis dies is it possible to home only this one axis?
    PS. Is the hard stop homing feature you mentioned a feature in VSD-A? If so, how does it work?
    15362
    ftec
    It is as accurate as your machine is Ballscrew Etc, & the same every time you home the machine
    Mactec54
    ftec Guest
    ftec
    I meant accuracy within appr. how many encoder pulses. When homing with external switches you can expect the 0 point to be a little different each time. Definitely must be a lot better when homing with the motor axis itself.
    What I'm after here is that once a rotational axis table has been aligned parallel to xy plane how accurately it will be parallel when homing with index or is a mechanical locking pin & adjusting still needed each time. (You can't answer this question for me though).
    15362
    ftec
    I did answer your question,It will be the same every time, The encoder only has one Z pulse/index pulse, if using this your machine will be 0.0 everytime
    Mactec54
    ftec Guest
    ftec
    Ok, I'll take your word for it then, sounds very promising. A short article of these extra homing features and how to use them would be good. They are mentioned on one line only in the manual.
    Sep 2004
    1207
    For overview, there are two videos demonstrating drive homing in action:
    http://www.youtube.com/user/granitedevices
    Please read also video descriptions.
    Repeatability is within one encoder count.
    Yes, or use home switch/hard stop homing to do that for you.
    Yes, disable does that.
    What you mean by dying? Faulting? No need to re-home it, just enable drive and it goes back to position.
    ftec Guest
    OK, that's it.
    The hard stop doesn't seem like an option in our case though it looked pretty cool. Instead, I can see that defining the machine zeros just a few pulses off from the index home positions will work for this machine: I'll just run all the axis to machine zero when quitting for the day. Then, after the homing to index, the homing sequences will offset the axis back to the machine zeros. If I also mark the zeros approximately to be on the right rev it's easy to recover if power fails.
    One last question at this point: The index wires are marked index+ and index-. Do both wires need to be connected to VSD-A or is the pulse measured against GND and only the positive or negative index wire is needed according to if it's negative or positive edge which is used? (I'm using BL servos).
    Sep 2004
    1207
    The index input is identical to A and B channel inputs, so connect it same way than A & B.
    ftec Guest
    OK, thanks.
    I'll try to remember to give feedback of how it went but it'll take some time to make the new wirings and changes.
    ftec Guest
    All four axes now have homing with Index and they seem to work perfectly and accurately. The positive Index Search Direction accepts negative values for Homing Offset so it was pretty easy to set the Homing directions the way I wanted.
    The only negative thing I notice after playing with it a while was that if - and when - re-referencing with Mach position is needed the power must be turned off to start the Homing sequence. Currently I have no switches connected to the VSD-A Home inputs. Is it so that with NO panel switches connected to the Home inputs each drive could be homed when ever necessary and not only on power up?
    Sep 2004
    1207
    Start of homing can be done two ways in VSD-A: on logic supply power-up or thru SPI bus. The power-up is the only practical way. VSD-E has additional inputs that can be used to initiate homing.
    ftec Guest
    Quote Originally Posted by Xerxes View Post
    OK, so the "Start Homing at power on" check box in the Homing Controller is intended for the SPI only and no tricks available there.
    BTW, are all the motor tuning values - including acceleration - applied as set when the motor is moved back and forth from within GDtools? What I mean is that the motors run much smoother when run from within GDtools via SPI configuration cable than from Mach. Setup values which work properly during the setup process don't necessarily work as well with Mach and many times I had to change the values after testing them with Mach. There is even a noticeable difference in motor sound. Perhaps this has something to do with the Step pulse quality or do you have another explanation? The machine is running OK with Mach so no problem there, just interested to know what this might be.
    ftec Guest
    Probaby relating to the last question in my previous post a weird thing happened the other day.
    I have the acceptable following error set to 50 pulses in the VSD-A setup for all axes. This is OK in my woodworking hobby as it corresponds to an appr 0.04 mm allowable measuring error. Never did this limit value result Following Errors and probably the value could be even smaller but I have had no need to test how low one could go.
    I then installed an AGP ATI VE display card in my Mach computer thinking it would free more resources for Mach to use if not using the OnBoard display system of the Intel Mother Board. What happened was that my heaviest X axis started to get Following Errors when ever Feed Rate exceeded appr 2000 mm/min. I then removed the card, all the relating drivers and programs and everything changed back to normal again.
    Fixed error: was 2000mm/s should read 2000mm/min
    Sep 2004
    1207
    Quote Originally Posted by ftec View Post
    I bet you're using step/dir from parallel port? The ATI card probably causes some jerkiness or jitter in step pulse train which equals very fast accelerations. Following error is higher during jerks compared to smooth motion.
    You're right. The trajectory generator inside drive generates 'perfect' acceleration ramps without any jitter. The output from parallel port is rougher including jerks from system load. The SmoothStepper can be a good solution if this bothers much.
  1. using encoder index for homing and a axes position
    By rokag3 in forum CNC Machine Related Electronics
    Last Post: 10-16-2009, 12:57 PM
  2. MFG.COM & First Index
    By leggetmachine in forum MetalWork Discussion
    Last Post: 04-02-2009, 06:59 PM
  3. How to use index pulse for homing purpose
    By Zig in forum LinuxCNC (formerly EMC2)
    Last Post: 03-28-2008, 08:16 AM
  4. Index ABC
    By chakrapani in forum Uncategorised MetalWorking Machines
    Last Post: 07-10-2007, 10:59 AM
