586,071 active members*
3,897 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Moving the Feed Axis with the Spindle locked?
Results 1 to 8 of 8
    Jan 2010
    Question Moving the Feed Axis with the Spindle locked?
    I have a Doosan 6030 Revo Mecatec mill with a Fanuc 0m control. I have a project that requires broaching a slot in the cylinder. Does anyone know how to get around the safety in the machine that prevents the axis from moving in Feed mode with the spindle off?
    I am trying to move the Z and X axis in Feedrate mode with the spindle locked in the orient position...Built in safety prevents me from doing this...
    Richard
    2932
    M84 allows feeding with the spindle stopped. M85 cancels M84.
    Jan 2010
    Not working...
    Tried that command...In our machine, M84 relates to the ATC...M59 needs to be use, then it wants to check for a pot down position.
    I've had to do this on other machines and it was a change in one of the parameters, but I can't find my notes to apply it on this machine.... Anyone else have any ideas on how I can do this? It's light broaching, so I figured if I can set the tool up, orient the spindle and set the tool manually so it's in the right direction I could get it done without removing the part and doing it as a secondary op.......
    Thanks!
    2932
    Sorry, M84 works on the newer Daewoo/Doosan mills.
    Try
    M184 = Axis Moving Valid when Spindle Stop
    M185 = Axis Moving Invalid when Spindle Stop
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Jan 2010
    18
    if your just doin light broaching, you can orient spindle-m19.then use rapid instead of a feedrate! just put rapid down to 25%!
    Quote Originally Posted by tizm View Post
    Im fairly certain you cannot G00 if you cannot G01
    Jan 2010
    18
    You can on a doosan , haas , supermax!other machines i dont know!
  1. R2E4 Boss 9 X Axis locked up
    By ironworksdesign in forum Bridgeport / Hardinge Mills
    Last Post: 06-29-2009, 12:54 PM
  2. Feed rates / spindle speeds for HF spindle
    By yngndrw in forum Uncategorised MetalWorking Machines
    Last Post: 03-21-2009, 04:46 PM
  3. Y axis moving without being programmed HMB-1
    By carbidecraters in forum HURCO
    Last Post: 06-22-2008, 06:51 PM
  4. Series I, Z axis locked in up position
    By marvfrankel in forum Bridgeport / Hardinge Mills
    Last Post: 04-30-2008, 09:30 AM
  5. Axis are not moving
    By Reef Guy in forum Mach Software (ArtSoft software)
    Last Post: 09-14-2006, 02:42 AM
