586,069 active members*
3,551 visitors online*
IndustryArena Forum > WoodWorking Machines > Uncategorised WoodWorking Machines > Digitizing with PCNCautomation routers
Results 1 to 7 of 7
    Apr 2004
    177
    I have a digitizing probe from Maxnc. I had limited success with it when using the Maxnc software. Now that I have Mach with the Digitizing wizard and the jack for tool setting, I wonder if I can plug in the digitizer and it will work with the new cnc and software? The digitizer has a plug which will need to be cut off and a new mini type one put on. Any ideas? Thanks.
    I talked to Bill Jounson about that and he said it should work well with the Mach3 Wizard.
    What does that scanner look like and how does it mount - just chuck it in the DeWalt?
    Please let us know how you make out.
    Apr 2004
    177
    Yes, it is a 1/4" shank and plugs in place of a bit. The probe is spring loaded. Well so far it will work when I pull down on the probe as opposed to pushing it up. Something must need to be flipped on or off somewhere in the parameters. There are plans for making a probe on the net that I saw today in my search. Search for digitizing probe and add mach to the search if you can't find it. I don't know much about mach yet to make any changes to anything.
    There's some wiring info in this E-bay add if it helps:
    http://cgi.ebay.com/CNC-3D-Digitizin...item4cebff4071
    This one has some extra features:
    http://cgi.ebay.com/Econo-Probe-Low-...item3a56277005
    Apr 2004
    177
    Thanks. When you see how relatively simple things they are, you can appreciate the lower price. You could probably build one with a simple homemade mill.
    Sep 2009
    21
    Quote Originally Posted by dobrientruckers View Post
    I talked to Bill Jounson about that and he said it should work well with the Mach3 Wizard..
    When was it you talked to Bill Johnson? Do you mind sharing his current contact information?
    Thanks.
    Sorry, it was early December before he went into stealth mode
  1. Vision Engravers & Routers New Large Format CNC Routers
    By CNC602 in forum News Announcements
    Last Post: 09-22-2009, 10:56 PM
  2. Need digitizing help
    By g450pilot in forum DIY CNC Router Table Machines
    Last Post: 05-03-2008, 12:39 AM
  3. digitizing
    By 70cyclone in forum Milltronics
    Last Post: 11-26-2007, 01:40 AM
  4. Digitizing
    By raygarrett1 in forum Employment Opportunity
    Last Post: 05-31-2005, 04:31 AM
  5. Digitizing
    By Michael M in forum Centroid CNC Control Products
    Last Post: 01-18-2005, 10:14 PM
