586,069 active members*
3,714 visitors online*
Results 1 to 11 of 11
    Jan 2010
    6
    HAAS VF8 ALARM 971
    Having Problems with my haas VF8
    Alarm code 971
    any advise would be greatly appreciated
    Oct 2009
    192
    Is this the alarm you are getting?
    Alarm 971 FAILED TO LOAD
    The on board device computer failed to load network drivers. This is
    from an invalid network setting. Cycle power. CNC should go into DRIVERS
    NOT LOADED mode, change network settings and try again. If you continuously
    get FAILED TO LOAD alarms without DRIVERS NOT LOADED mode, notify your
    dealer. Note: The default network settings can be restored if needed.
    Press PRGRM CONVERS during power up, then Press P ENTER, then P5 ENTER.
    If it is then it is an ethernet alarm.
    Do you have ethernet?
    Has ethernet worked before?
    Jan 2010
    6
    I do not have ethernet on the machine.
    Oct 2009
    192
    What software version do you have?
    The software version can be found on the screen when you first turn the machine on.
    Jan 2010
    6
    Version M14.021
    MOCON 12.06
    Oct 2009
    192
    Could you confirm, is that
    14.21
    or 14.02?
    14.021 isn't a correct software version
    Jan 2010
    6
    My mistake, 14.02. It reads 14.02I
    Oct 2009
    192
    ok.
    Check parameter 57
    about half way down left side
    should read 'network/usb' or something like
    is this a 1 or a 0
    should be 0
    Jan 2010
    6
    Can't find it anywhere is parameter 57 menu. Could it be the "unused" option?
    Oct 2009
    192
    It's the one about six down from top that actually says unused or reserved on yours.
    Your problem is a software fault.
    You need an upgrade to at least 14.03b
    Only your HFO can do this.
    Hope this helps
    Jan 2010
    6
    Thank you so much for the help, I'll get an update in the works.
  1. ALARM shuttle drawbar alarm haas
    By timmydabull in forum Haas Mills
    Last Post: 02-18-2013, 07:47 PM
  2. Alarm 157 Haas VF3-SS
    By rshields21 in forum Haas Mills
    Last Post: 12-09-2011, 09:03 AM
  3. haas 160 alarm
    By s00073055 in forum Haas Mills
    Last Post: 10-22-2009, 06:19 PM
  4. Haas VF2 ALARM 127 &115
    By grease in forum Haas Mills
    Last Post: 10-18-2007, 09:31 PM
  5. Haas alarm 165?
    By UBRacing in forum Haas Mills
    Last Post: 07-08-2007, 05:43 PM
