586,089 active members*
3,874 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > servo drive position control by analog 0-10Vdc or 4-20Ma
    Feb 2006
    213
    I am looking for a servo drive to control a position of valve or cam (0 to 270 deg. movement) by analog command 0-10Vdc or 4-20ma. kindly suggest me a suitable and low cost servo drive.
    24221
    I have used A-M-C products, also I made up a solenoid controller for a hydraulic servo valve from a single IC that worked well, +-10vdc, National LM759 with a few resistors and caps.
    What are you using for the 0-10v command?
    Al.
    Albert E.
    Feb 2006
    213
    Thank you very much for your reply. Actually I want to make a fully servo controlled position control valve using servo motor, earlier I was using electro pneumatic position control valve like ABB, siemens make controlled by analog 4-20ma from PID controller, as pneumatic devices are very senstive to mositure, it gets damage very soon. could send me the details of your solenoid controller that you made? it might be useful for my application.
    Al.
    24221
    This is the link, see p10 for the DC motor control, I fed the analogue out from a motion card and used an encoder back to the card for control, it worked well with a hyd servo valve.
    http://www.national.com/ds/LM/LM759.pdf
    Al.
    Albert E.
  1. PWM and DIR -> +/-10VDC analog signal
    By visky in forum CNC Machine Related Electronics
    Last Post: 11-21-2007, 09:28 PM
  2. How to drive Analog Servo Input +/- 10V
    By gurvy in forum CNC Machine Related Electronics
    Last Post: 05-31-2007, 05:31 AM
  3. want to built servo drive(analog and digital)
    By grebator in forum Servo Motors / Drives
    Last Post: 04-03-2007, 04:29 PM
  4. Reconfiguring Yaskawa Drive for Position Control?
    By rpseguin in forum Servo Motors / Drives
    Last Post: 11-01-2006, 02:09 AM
  5. connecting 4-20mA device to analog input
    By Karl_T in forum CamSoft Products
    Last Post: 09-02-2006, 06:52 PM
