hi all, i pulled trigger and bought the nm-200 a while back, and i have it all setup, and everything works but the spindle control is all or nothing. i changed some stuff around as per info found while researching, and i can get it to control speed, but actual speed is double what i put in. it works when set to 50% but that cant be right. i tried installing the novakon nm-200 xml file off both the usb key included and off the website, and both when insatlled/open mach with that profile cause everything to fail. nothing moves except the dro number change according to the program or jog commands. when i reinstal the mach3mill.xml, everything works except spindle control. hope that is clear enough. i was wondering what some of you may be using for spindle control settings in ports and pins/spindle control? thanks
