When I try to enter the commands (M, G, S) THROUGH THE MDI, and press the Start button, these values are not copies
DOES ANYONE HAVE AN IDEA WHY DO NOT COPY THE VALUES????
You don't use the "Start" button to input the values, only to run them once input. We have one 6T control in our shop and it is programmed by the other programmer, so it has been a while since I have been on the control. There should be an "Insert" key. If not that , then an "Input" key. May have to press the far right (or possibly the far left) soft key to bring up the right command to insert. Pretty sure it is "Insert" not "Input". Believe it is "Input" on an OT control.
First you have to be in the COMMAND input screen, With your mode selector turned to MDI press the "COMMAND" button then the "PAGE DOWN" button, enter your command then push the "INPUT" button then the "START" button.
Jerry
With the selector in MEMEORY mode push the O (ooh) key (not zero) and then the down currsor key, repeat, and you can scroll through all of the programs currently in memory.
Jerry
