586,100 active members*
2,657 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to drill VERY accurate holes?
Page 1 of 2 12
Results 1 to 20 of 21
    Nov 2006
    85
    Hello people
    Since I`ve got my IH mill, I`ve been doing some hole drilling in regular steel. But on some of the parts I`ve drilled, the hole need to be VERY accurate. Before I drill the hole I use a metal scriber to mark where I want the hole. But when I drill the hole with regular HSS drill bit, the hole often gets 1mm of center (where I made the mark with the scriber).
    So the question is, how do I make VERY
    accurate holes with my mill? Do I have to use some other cutting tools?
    Apr 2008
    1577
    Accurate location wise or hole size?
    Use a center drill first, always. I have a few drills that are stout enough to punch a hole in steel without walking but my machine is also very rigid. Center drill just deep enough to get a small chamfer at the top of the pilot hole, then follow through with the drill.
    If you are concerned about size you should take into account that most drills will drill slightly oversize. Look up some drill charts on the web and some of them will tell you the probable amount of oversize. If it really needs to be VERY accurate, drill the hole slightly under, then finish with a reamer.
    Not sure of your application and would like to hear some other folks input but that's the way it's done here.
    Sep 2007
    359
    Sorry, but there is no way to drill holes "Very Accurately "
    If you need accurate holes they need to be drilled, then bored to size.
    If you need super accurate then they can be ground to size, using a jig grinder.
    Phil
    Nov 2006
    85
    Thanks guys.
    I meant accurate location wise. It don`t need to be extremely accurate, like 1/10mm in tolerance. So I think i will try to drill with a center drill bit first. I will buy some center drill bits and try that method.
    But what about end mills, I guess there are some types of these that I can drill holes with? That way I only had to do one step to make the hole. What do you think about that?
    Sep 2007
    359
    You will not get very accurate holes with end mills
    First they have to be designed for plunging.
    Second unless your machine is very rigid the X & Y will get thrown around when you try to plunge. It will do this on a Bridgeport.
    They "Endmills" will also drill slower than a drill if no pilot is used.
    You can of course use an endmill after rough drilling to clean the holes up.
    Phil
    15362
    Hi Sperstad
    You want to use a spot drill not a centre drill, a centre drill will work but is not needed for drilling holes a spot drill is all you need
    You can get a drill, mill, chamfer cutter combo, but this depends on the size you want to drill, there is not many sizes to choose from
    Mactec54
    Mar 2004
    1543
    Hi Sperstad
    He's right, spots are WAY better than center drills. For one step drilling a stub length spot drill in a collet or end mill holder (as opposed to a drill chuck) does very accurate work.
    Karl
    Jul 2005
    12177
    Have a look at this link:
    http://hassaysavagecompany.thomasnet...ls?plpver=1001
    You need a spotting drill, 90 degree if you want to spot the hole slightly oversize and leave a small chamfer after the drill hase gone in; 120 degree if you do not need the chamfer. In both cases larger than the largest hole you will be drilling.
    Center drills are intended for drilling holes in the ends of shafts to turn them between centers on a lathe; these have the reduced diameter pilot and then a 60 degree taper section. You will find them described as 'combined drill and countersink' which is a nonsense name because they are neither.
    You can use a center drill for spotting a hole but it is not the best choice, if you are following it with a carbide drill it is a bad choice. The pilot on a center drill has a fairly wide web for its diameter and in a drill press with some looseness this web can wander a little as it contacts the material so the alignment may not be ideal. Also the pilot is small and if it is used to simply make a small dimple this may not give good centering for a considerably larger diameter drill; which is why you will see it suggested that the center drill is taken deep enough to enlarge the hole on the 60 degree taper. This is a bad idea for two reasons: First, because you have a pilot hole the web of the final drill does not make contact with the material before it starts cutting full diameter so it does not get a self-centering and stabilizing effect; this means the drill can, and often will, chatter and wobble at the start of the hole giving a rough and tapered entry. Second, when a carbide drill is used this chatter will almost certainly chip the cutting edge leading to premature failure of the drill; it will also cause premature failure with HSS or cobalt drills but maybe not as quickly as with carbide.
    Spotting drills are made for spotting holes to give a precise starting location for a drill. The web on a spotting drill is thinner than than that on a center drill pilot of the same diameter and the end clearance is reduced so a spotting drill has some tendency to self center. Spotting drills have no flank clearance and are not intended to go deeper that the angle on the tip which is why a diameter slightly larger than the intended hole size should be used so the spotting can be done to a diameter close to or slightly larger than the final hole. This shallow depth for the spotting drill means that the web on the final drill makes contact with material almost immediately and definitely before the drill is cutting at full diameter giving a much cleaner entry. When a 120 degree spotting drill is used a normal 118 degree drill makes contact on the web before the entire cutting edge is engaged giving the smoothest start possible and this is preferred for carbide drills. When a 90 degree spotting drill is used to spot deep enough to leave a chamfer then the corners of the cutting edge on the drill make contact with the spotted hole before the web makes contact. This can cause a little chatter before the web makes contact and is not good practice with carbide drills as it can cause chipping and premature failure; HSS and cobalt drills are more resist to chipping but slightly shorter drill life can be expected.
    May 2005
    2502
    What they said, but some other thoughts:
    Definitely go spotting rather than center drill. I like to use stub length and larger diameters. You can only cut with the tapered point, so the hole has no idea the diameter and a larger diameter is more rigid.
    Use a screw machine length twist drill. The shorter your twist drill the stiffer it is. If you need a really long length for a deep hole or to reach into a tight space, consider carbide. It is stiffer. You can go deeper just like with a solid carbide boring bar.
    It's really painful to accurately locate center punched holes. I prefer to edge find some feature and let the CNC find the holes relative to that feature.
    Make sure your drills are SHARP. It's amazing what a difference that will make. Also, based on the material, different end geometries can make a difference. Depends on your application whether it would be worth your trouble. Even just having a cheap Drill Doctor to keep the points sharp really helps.
    Cheers,
    BW
    Try G-Wizard Machinist's Calculator for free:
    http://www.cnccookbook.com/CCGWizard.html
    Jan 2007
    1389
    Quote Originally Posted by Sperstad View Post
    Thanks guys.
    for accurate location wise use a dial indicator.
    Oct 2005
    1237
    Times are achanging. I'm an old fart. Retired before some of the new stuff came in. (some? a lot of stuff) We used center drills for all important hole locations. Forthe most part they work well. A hobbyist with a full index of drills needs an inexpensive way to spot them with accuracy. Center drills do this quite well. I see now in the 21st century there is a better way, but the old way worked well enough that I don't think someone on a hobby budget actually needs a full set of spot drills, and a drill index.
    Lots of reasons were given why center drills are a bad choice, but they will hold your hole within +-.002. If you need more precise than that, by all means, buy a set of spot drills. If the holes are merely for bolt clearance or tapped holes, a set of spot drills is a waste of money when a simple center drill will cover a wide range of drill sizes.
    Jul 2008
    411
    How are you centering your spindle over the markings?
    Its all very well having the debate of spot v centre drills (and I use both, but favour centre drills simply because I have several and they are cheap to replace), but the iisue seem to me to be that you are eyeballing the drill tip to the marking... before using a centre drill you still need to get the spindle accurately centred over where the hole needs to be... and for that you need a wiggler, or an edge finder if you can locate the hole relative to two perpendicular edges... unless of course you are relying on a DRO but then you wouldnt really need a mark, you'd just dial in the location...
    If you're in Europe why not come and visit the UK CNC Community at http://www.mycncuk.com
    Oct 2005
    1237
    Back when... When using a Radial drill for drilling die sets, we'd use a solid Drill blank ground with a point to locate the drill over the spot we planned to drill. First we'd center punch the hole location using transfer punches with the die steels, then locate the drill with the center ground drill blank, then center drill, and finally drill the hole. Drills never wandered and die steels always lined up with their respective bolt holes.
    Jul 2005
    12177
    Quote Originally Posted by MrWild View Post
    Back when... When using a Radial drill for drilling die sets, we'd use a solid Drill blank ground with a point to locate the drill over the spot we planned to drill....
    Done that.
    Leave the column and arm locks loose and hold the blank ground drill in the center punch mark with the spindle running slowly and lock them gently; you could get amazing precision this way.
    Back when my eyes could see fine detail better I would lay out bolt circles with dividers and straightedges, center punch and drill and on a good day keep within better than plus/minus 10 thou.
    Apr 2008
    1577
    Ding ding!
    The center drill vs. spot drill debate has a place and will always ignite healthy exchange of idears. But for a "hobby" mill (IH = Industrial Hobbies), I doubt that any of the benefits of a spotting drill will bear much fruit. Again, open to discussion.
    EDIT: For what it's worth, I don't use spot drills on my CNCs either. Even with the aid of precisely controlled feed and rigidity, the fine chisel point doesn't make them a good choice for us. A good center drill lasts me "forever". I would definitely be interested in an independant review of the benefits of spot drills vs. center drills. I'm always looking for a better way to do things, I just haven't seen it yet.
    May 2005
    2502
    Quote Originally Posted by SBC Cycle View Post
    I won't quote any accuracy advantages as the others have already commented. But there are other advantages:
    1. They're just more durable than center drills. No delicate center tip to break off. If you've never broken a center drill tip, you won't see this as an advantage.
    2. You don't need a whole set. Even just one single 1/2" is very versatile and that diameter in a stub length makes it very stout. You are only able to use the tapered tip anyway, so as I said before, the hole doesn't know the diameter of the tool except for the portion that protrudes into the hole.
    3. You can countersink FHCS with one without have to do a tool change. They're available in all the right angles. That potentially saves time even if you have a toolchanger, but it really saves time if you don't.
    4. You can engrave with one, which may save yet another toolchange, depending on the project. They actually do a decent job engraving if you don't get too carried away.
    5. You can chamfer with one. The operation is just like engraving. There goes another toolchange saved.
    6. They're cheap. $8 for a 1/2" Keo name brand from Enco as we speak. A half inch center drill (#6) from Keo is $13.
    If you wonder about all this spotting, countersinking, engraving, and chamfering, take a look at the video of the Nine9 indexable spotter, it's very cool:
    [ame="http://www.youtube.com/watch?v=wO65mdsSC3Y"]YouTube- NINE9 NC Spot Drill[/ame]
    Of course they'll sell you a center drill insert too if you prefer!
    Cheers,
    BW
    15362
    Hi BobWarfield
    Yes the Nine9 is very good I use them they are not cheap but once you have one you won't go back to anything else,were you need to get in tight places these are great as well sold by Enco drill mills
    Mactec54
    Dec 2005
    183
    I'm going to jump on the spot drill bandwagon. I finally bought one a few months ago and I'm not looking back. My center drill stays with the lathe now. I've been using a .5x3 spot drill and I like that fact that it's closer to the length of the drill I'll be using but still sufficiently rigid to spot accurately. Fewer cranks on the knee...not an issue with CNC though.
    Apr 2008
    1577
    Hi BobWarfield
    The Melins are what I have in my hand right now. I've tried the spot drills twice. Once on the recommendation of a tool supplier about 5 years ago, the second time was 2 months ago when we hired a new guy.
    With the tool rep here in the shop, the spot drill worked "ok". Using their recommended speeds and feeds on a stainless part, the point didn't last more than 4-5 parts (10 holes in each if I recall) before the spindle load meter started creeping up. That wasn't the big problem though, we were seeing premature wear of the HSS Cobalt drill. It's just a guess but it seemed to me that as soon as the spot drill started to wear, the material was work hardening. We were able to increase the life by substantially lowering the feeds and speeds - but ended up right back to were I was with a fine quality center drill.
    I tried them again when the new guy raved about them. I bought half a dozen 3/8" SC Melins and pretty much had the same result. What sealed it for me was when he took time out to change the spot drill for the second time in 3 hours. I asked how things were going and he said "great!" I swapped out the spot drill for a center drill, backed the rpm and feed down a bit and he ran the rest of the job trouble free.
    The 82 degree center drills I'm buying run about 30 bucks for a double end. That puts them about the same price as 2 or 3 single end spot drills. My experience was that the spot drills were slightly quicker but not enough to justify the downtime changing out tools.
    To be honest, I'm not quite pleased yet with either method which is why I asked for other comments.
    Jul 2005
    12177
    ..... spindle load meter started creeping up. That wasn't the big problem though, we were seeing premature wear of the HSS Cobalt drill. It's just a guess but it seemed to me that as soon as the spot drill started to wear, the material was work hardening......
    Working with stainless is one time it might be better to omit using either a center drill or a spot drill for this very reason; even when in good condition it leaves a work hardened surface for the drill.
    Depending on the hole placement tolerance sometimes it is possible to go straight in with a stubby cobalt drill choked up as short as possible is a collet holder for best concentricity at the tip.
    Failing this a HSS spot drill or center drill is better than carbide in my experience; carbide tends to chip at the web due to the higher contact pressures encountered with stainless.
Page 1 of 2 12
  1. Drilling VERY ACCURATE holes in delrin
    By kbspeed in forum MetalWork Discussion
    Last Post: 07-20-2009, 10:41 PM
  2. Need to drill 4/5" holes...
    By Sperstad in forum Charter Oak Automation Support Forum
    Last Post: 04-06-2009, 07:33 AM
  3. Trying to drill many #8 holes.
    By ErnieD in forum MetalWork Discussion
    Last Post: 05-10-2008, 06:17 AM
  4. Drill holes with end mill or twist drill ?
    By Argofanatic in forum MetalWork Discussion
    Last Post: 12-30-2006, 05:05 AM
  5. drill dwell between holes
    By EVERFABCHAD in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-11-2006, 01:15 PM
