I need to get some suggestions on machining these plates. I normally on machine around 20 to 50 parts so I usually don't make small fixtures.
I need to make 200 of the plates attached (1 time order I know the project so it won't repeat other then 1 or 2 pcs).
I was considering using the carrier method (order the stock thicker then necessary, machine the entire part and flip it over to machine down to thickness).
My on concern there is only 2mm. Worst case is to use the thru holes but that didn't seems time consuming.
Any thoughts?
On Edit: Material is 4140 Steel
