We have VF - 6 where is warm up cycle is it in program list or some where else,or you have to make your own,Machine is built in 1998.Thank You
Program O02020 is the warm up cycle, if you don't have this in your machine you can write your own.
Start at 500rpm and program a G04 P200. for a pause of 200 seconds, then 1000rpm with same pause, then 2000, 4000 etc until you reach top speed.
we have a tm2 and use the following with table moves as well
starts off slow feed and slow spin, and gradually gets faster.
if you want longer then just change the loop counts
we set G126 to approx the center of the travels in x,y and z about 150mm from top stroke.
(Spin/Table G126 NO TOOL)
M01
G126 G90
S500 M03 F2000.
M97 P100 L2
S1000 M03 F3500.
M97 P100 L2
S1750 M03 F5000.
M97 P100 L2
S2500 M03
M97 P100 L4
S3500 M03
M97 P100 L4
S1500 M03 F2500.
M97 P100 L2
G01 X0 Y0 Z0 F5000. M05
G54 G90
M30
N100
G01
X350. Y200. Z0.
Y-180. Z-300.
X-350. Y200. Z0.
Y-180. Z-300.
M99
Your program works fine. I was looking for a warm up program that did more than just warm up the spindle.
In between the spindle speed change I move the table around the 4 corners at 5% rapid. I think that will hopefully lube the linear ways because I seldom use up the full X or Y travel range during normal operation.
