I acquired a Thompson ball screw off of EBay which seems to be in good condition and I was thinking of using this for my Z axis on my Mini-Mill conversion.
The ball screw appears to have a diameter of .7235 inches and a lead of .2. I don't know if it's ground or rolled, but there is a small grove on the 'apex' of the threads if that helps (you can see that on the pics).
The thread portion of the ball nut appears to have a diameter of 1.2465
There is no apparent backlash (testing by hand) and the nut takes a little force to turn but all in all it's quite smooth.
What I would like to do is purchase an additional length of ball screw (about 30 inches), have it machined and then transfer the screw over.
So, my questions are:
What are the specs on the screw and where can I get a short length?
What are the specs of the thread on the ball nut, so I can a get a flange and where?
Finally, what are the issues of transferring the ball nut from one screw to another?
Phil
