587,072 active members*
3,091 visitors online*
Results 1 to 11 of 11
    Mar 2009
    12
    mazak h500 question - m code
    Hello i have a mazak h 500 and i need an m code function how to turn on the AIR blast thru the spindle,i know i can turn it manual,i want to know if there is an special m function for that
    Thanx
    Dec 2007
    300
    M50
    Mar 2009
    12
    I know for m 50 and it does not work
    Mar 2005
    988
    M code Air Blast was an option on the H500s as well.... Do you even have it?
    It's just a part..... cutter still goes round and round....
    Mar 2009
    12
    Yes i can turn it manualy in the coolant menu
    Feb 2007
    198
    My guess is that it may be a PLC parameter, like "air blast on by M50" or something like that. Or it just may not be possible to do it by program?
    This is an older machine, correct? what version Mazatrol is on it?
    -jim
    Mar 2009
    12
    You think there is an parameter to turn that option on?
    Do you know maybe what is that parameter?(i think that is a little bit to much,)
    Yes that is an older machine from 1989.Its an m-32 mazatrol control
    Thank You on your answer
    Dec 2007
    300
    I don't think it was an option. All Mazaks use spindle air blast during a tool change so if it works then it should work by calling M50 or M132 in the program.
    Mar 2009
    12
    thank you on your respond
    it is M132
    THANK YOU
    Mar 2005
    988
    All mazaks use air blast in toolchange but the M code was a "standard option" back then. Some models standard... some models option... (just the M codes)...
    Being an H500 I should've thought about that ... standard on horizontals .... (my earlier remark is an error..)
    Jun 2009
    4
    Quote Originally Posted by stefo View Post
    Thanx
    We are using macak 8800 m50 is air on not air thru M132 is air thru
    I can only get it to work using M119 S0 . I am using this to blow out part for probing bore. I us G1 with a z move feed rate and put in M132 so air thru will come on then use M9 to turn it off, the M119 S0 will set spindle at a angle
    on the 8800 M119 S0 will set spindle at 0 I hope this helps.
  1. NEED POST FOR MITS M-H500 W/MELDAS M3 CONTROL
    By jzolli76 in forum Post Processors for MC
    Last Post: 01-06-2010, 04:44 PM
  2. POST FOR MITSUBISHI M-H500 W/MELDAS M3 CONTROL
    By jzolli76 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-05-2010, 07:46 PM
  3. NEED HELP WITH A POST FOR MITS M-H500 W/MELDAS M3 CONTROL
    By jzolli76 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-05-2010, 06:48 PM
  4. Help with mazak g-code
    By dgchumley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-02-2007, 09:32 PM
  5. g code mazak
    By robs_96 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-16-2006, 08:17 PM
