586,069 active members*
3,454 visitors online*
    Feb 2007
    64
    save g code as
    I just downloaded EMC2 and am learning the ropes.
    I want to save one of the example programs to use as a starter program to play with.
    I clicked save g code as
    type in the name for the new program
    click save
    It does not work ,just disappears, Is there something else I need to do?
    May 2005
    1662
    Are you sure the file isn't simply misplaced ?
    Try it again and make sure it's being saved in your /home/user-name directory
    warning: I'm using an older version of Ubuntu and might be seeing a different file dialog box.
    edit/ that file dialog box has a built-in 'gotcha'. It won't display a warning when attempting to save a file to a directory that isn't user writable. The file won't be saved in that case.
    Anyone who says "It only goes together one way" has no imagination.
    Feb 2007
    64
    Thanks for the response.
    I found it! It was in documents.
    It only took me about half a day to figure that out !
    I have been reading up on the linux filing system, but have not made much sense of it yet.
  1. Save G-Code
    By Rally in forum HURCO
    Last Post: 08-19-2009, 06:04 AM
  2. Save as *.stl
    By christodoulos77 in forum Mastercam
    Last Post: 03-27-2008, 02:54 PM
  3. Save as ????what
    By jorgehrr in forum Mastercam
    Last Post: 10-29-2007, 12:42 PM
  4. Save As .JPG?
    By TZ250 in forum BobCad-Cam
    Last Post: 09-28-2007, 01:56 PM
  5. How Do I Save As .JPG, .TIF or .BMP?
    By TZ250 in forum Dolphin CAD/CAM
    Last Post: 06-02-2007, 03:17 PM
