I have started buying components for a Power Drawbar for my NM-135 as I don't have 3 hands and the NM-135 with TTS requires 3 (two to loosen the drawbar as there is no spindle lock) and one to catch the tool holder.
I want to keep the power drawbar as compact as possible and with as few moving parts so I want a direct acting air cylinder rather than using levers.
I ordered this Fabco cylinder from ebay http://cgi.ebay.com/ws/eBayISAPI.dll...#ht_700wt_1167 which has a 4" bore and 1' stroke which I think should be more than enough force. It has a non-rotating piston which should help avoid the drawbar un-screwing over time.
I also ordered a 4 Way 2 Position Hand Lever Pneumatic Valve 1/4NPT Momentary for manual control and will change to solenoid at a later date when/if I add an ATC.
Additionally I ordered a One Touch Push In to Connect Speed Control 1/4" OD Tube and a filter/ muffler plus some 1/4 npt - 1/4 od quick connect fittings.
Having never played with pneumatics before, can someone give me a simple "circuit" diagram of how to plumb the cylinder to the valve to the compressor.
Now I need to design the power drawbar , but as the top plate on the mill head is approx. 1/4" steel plate which is easily removed I will be mounting the cylinder to that using stand offs.
David
