Originally Posted by
rbach
For some reason out of the blue yesterday my z drive locks up when trying to jog up at full rate. It sounds as though its getting pulses to go in both directions and if you hold the jog up button down you can actually see the spindle slowly move in a downward direction even though the DRO is still coutning up.
It moves down fine and if I set the jog rate to slow jog rate to 90% it will work fine but nothing more than 90% and it will lock up again.
It does this when trying to run a program as well when the machine attempts to move to rapid clearance height it will lock, the DRO will get out of whack and the program is shot.
Running Mach 3, did an upgrade yesterday to see if that would fix it, no help. full reboot and shutdown of all systems no help.
Have made no changes since thursday when the machine ran fine.
Any suggestions on what the issue may be and some trouble shooting tips.
Randy
