586,108 active members*
3,097 visitors online*
    May 2009
    41
    Missing steps
    Hi guys,
    working on my first machine and I am using a Hobbycnc pro controller and mach3. I set up motors the same but my Y axis is missing steps. Any help would be greatful.
    Kasari
    Dec 2004
    1316
    Your accel might be too fast in mach3.
    Your top speed might be too fast
    Check if there is binding in the Y axis. You willl need to remove the lead screw and push the gantry along the rails, it should be smooth all the way.
    May 2009
    41
    Thanks Jason, I will check that.
    May 2009
    41
    Jason,......Thanks for the info. I found the problem with the motor not aligned correctly. But, I fixed it.
    Again, Thanks
    Dec 2004
    1316
    Glad to hear you found the problem and fixed it. Now you need to get busy making chips.
    Jason
  1. reasons why a stepper maybe missing steps
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 10-14-2009, 06:20 PM
  2. Missing steps?
    By beezerlm in forum Machines running Mach Software
    Last Post: 05-13-2008, 03:59 AM
  3. Missing steps ?
    By DavyD in forum Machines running Mach Software
    Last Post: 05-10-2006, 08:06 AM
  4. Missing Steps with Laptop
    By alanc2 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-08-2004, 08:39 PM
