Blimey, I got mine for GBP 12.23 from RS last month but they've jacked their price up by a fiver since then
I went for one atmosphere pressure, but 3psi should be plenty enough for pnp. They Honeywell range has 1psi and 5psi, didn't see a 3. The hysteresis is .15% of the sensor span so my 15psi part is okay for any vacuum.
I was planning on a vacuum reservoir with the sensor deciding when to turn the pump on. Didn't seem like a good choice for pick up detect but could be worth a try. I suppose I should look for the vacuum decay rate with the pump off
