586,106 active members*
3,134 visitors online*
Results 1 to 10 of 10
    Sep 2007
    119
    CNC pinewood derby car
    My nephew asked me to help him make a "Awana Grand Prix" car, these are pretty much the same as the BS pinewood derby, but it is a church run group. So, we set out to make one on the CNC mill.
    Before anyone gives me crap about doing this for him, the only thing I am doing is setting up and running the machines. He's only 12, and I am trying to teach him about the machines and the software. I helped him design the model in sketchup, we exported it to 3ds format and imported it into artcam. I setup the tool paths, and he's doing all the finish sanding. The car is also going to have working LED headlights, and so he's going to learn some very basic electronics stuff as well.
    I have no idea how this thing will preform, we were going for more of a really cool look.
    Here are the pics so far:
    Model roughed out
    3d finish passes, and a lot of hand sanding
    Later,
    Jason
    Jun 2005
    305
    Looking pretty cool!
    ObrienDave. MasterCam since V6. Gcode since 1983.
    The nose you punch today may belong to the butt you have to kiss tomorrow.
    Sep 2007
    119
    Here is where we are today. Electrics are in for the headlights. Twin 3mm white leds, a little push button switch and a 3v lithium coin cell. Machined a little cowl today to cover up the battery and switch, you have to remove the cowl to turn the lights on and off though...
    The wiring channel is going to get filled with body filler here in a few minutes, and we'll fill the chips and holes that were from mounting it and machining it. We're at 3oz right now, limit of 5oz, so we have room to go with weight.
    Here are some pics:
    Later,
    Jason
    Sep 2007
    119
    Here are some progress pics from today. He changed his mind on the headlights, we went from white to orange (they show up yellow in the camera) today, luckily I hadn't glued the white ones in yet.
    Anyhow, lights are permanent now, we've filled the channel with bondo. We made a little wing for it, and glued it on. Also changed the design for the cowl a little bit to allow access to the switch underneath w/o having to remove it. Hopefully, tomorrow after he finishes sanding it, we'll will be ready for paint.
    Here's the pics:
    Later,
    Jason
    Feb 2009
    6028
    Let me know if you can do a Porsche 914 ! Very cool, and I know a lot of people who would want one !
    Jan 2010
    Get the weight as far forward as you can...makes'm faster out of the gate.
    Sep 2007
    119
    Well, it is almost done, and I am out of time to help, I go back to work tomorrow night.
    He sanded entire car progressively smoother from 60grit to 320grit. We shot it with rattle can primer, he sanded again, we shot two more coats of rattle can metallic paint, and am calling it done. We still need to add two ounces, still hovering right around 3.1oz. Maybe my digital scale sucks...
    Anyhow, here is the end result:
    Later,
    Jason
    Apr 2007
    24
    We used to drill holes underneath in the front with a forstner bit and screw in a set of washers. I agree with getting the weight up front for speed.
    Sep 2007
    119
    Well, my nephew couldn't skip anymore school for this, so I tied up the loose ends today. I got the wheels and tires on, added the weight, polished out the aluminum cowl, and made a little "key" for him to switch the lights on and off with. I'll let you all know how the races come out!
    Later,
    Jason
    Mar 2008
    309
    Cool car.
    My seven years of research has shown that weight in the front adds stability, weight in the rear adds speed. I would aim for a CG about .75" to 1" forward of the rear axle. Balance the car on a ruler edge to find the CG.
    Why? Because the further you get the weight from the bottom of the track, the more energy goes into the car. Height equals energy. Energy equals speed. It's simple physics.
    If you want the car to "come out of the gate" faster, cut the wheels to reduce their rotational inertia. Your local rules may or may not allow modifying the basic shape of the wheels. Depending on the shape of the track, you'll want to balance low inertia hole shot with high inertia runout at the end of the track. In other words, if the track has a long flat section after the initial ramp, you may be better off with more rotational inertia in order to keep the speed on the flat part. If it is all ramp and no flat runout, you almost assuredly want very low rotational inertia.
    Finally, reducing friction by polishing bearing surfaces on the axles and wheels (and possibly reshaping them) will always pay off.
    On the other hand, sometimes the car with sticky wet paint and the wheels stuck on sideways just happens to run just right...
    Enjoy the race!
    Regards,
    - Just Gary
  1. PINEWOOD DERBY
    By bhuss in forum Hobby Discussion
    Last Post: 08-05-2017, 02:02 PM
  2. Pinewood derby car
    By andedwa in forum WoodWorking Topics
    Last Post: 04-05-2016, 02:16 PM
  3. demolition derby
    By kyle.markins in forum Hobby Discussion
    Last Post: 04-05-2016, 08:36 AM
  4. BSA pinewood derby cars
    By Drew in forum WoodWorking Topics
    Last Post: 02-21-2009, 04:16 AM
