586,588 active members*
2,907 visitors online*
Results 1 to 8 of 8
    Feb 2009
    129
    USB Drive Viruses
    Not sure what category to put this in.
    I want to know what you do to keep your machines safe from customers viruses.
    My company just got a crippling virus off of a USB drive that we use to bring files to outside processors. We want to set up something to scan them before we put them back in our machines and bring down our network again!!
    Is there such a thing?
    Sep 2006
    i use this,
    RRT v5.0.0.15 - Sergiwa Antiviral Toolkit
    4826
    You might want to research 'disabling autorun' in Windows.
    I believe default Windows behaviour is to look for an autorun file on any drive which is plugged into the USB. Executing the autorun is most likely when the virus installs itself, perhaps before your virus scanner even has a chance to scan the files on the disk.
    Yes, you will then have to search for the files on the disk using windows explorer as the pop-up window will likely cease to pop up when autorun is disabled. Not a big deal for a bit of security.
    Feb 2010
    371
    My daughter brought one home on her USB stick a couple of years ago, and as mentioned, it made use of the autorun.inf file on the stick. The virus was actually cleverly disguised, made to look like a hidden system trashbin folder rather than an executable. I installed a free program called AutoRun Eater that checks removable media when you insert it.
    http://oldmcdonald.wordpress.com/
    Nov 2005
    1468
    Yer, disable the autorun, my mate caught a virus off of a USB stick, it hit his PC, his music Hard Drive (he's got one of these Terabyte HD's... figure how long to scan), his freaking iphone thing (it scanned every 30 seconds or so for stuff to copy itself to, if I recall). The virus also knocked out the ability to disable autorun and various other options that you would normaly use to get rid of it it took me hours to fix it "Hacked By Godzilla" appeared on the top of the address bar.
    I think it was technicaly called a worm more than a virus. Pain in the arse to get rid off.
    If it was "Hacked By Godzilla" thing lemme know, I got how to get rid of it written down, printed out and stuck on my wall.
    I love deadlines- I like the whooshing sound they make as they fly by.
    Apr 2005
    3634
    Win, USB Drive, disable Autoplay:
    1) Open Windows Explorer or press the Windows + “e” key.
    2) Right-click the drive of the USB Drive (then select "Properties", Drive Properties will appear).
    3) Select the AutoPlay tab.
    4) Choose Select an Action to Perform
    5) At the bottom of the selection, click Take no Action, then click Apply.
    6) Click OK to exit Drive Properties.
    Then create a shortcut, from the USB Drive to the Desktop, makes it faster to find the USB Drive, later.
    Always scan the USB Drive with Antivirus program (Avira, etc...)
    Free DXF - vectorink.com
    Sep 2006
    If you have only one PC and a single user it is quiet easy to protect it.
    but in a office environment ( not all are tech savy even if you disable autorun and some one double click the usb you wil get infected)
    Download (Flash_Disinfector.exe)and run this while you have your usbdisks in slot.what this software is doing is making a folder by name of autorun.inf on all disks and usb or mobiles with window permissions not to be overwritten by any virus or worm( so they can't replace it with autorun.inf file).
    http://download.bleepingcomputer.com...isinfector.exe
    Sep 2004
    412
    FYI,
    There are some of the China USB jump drives that have an embedded rootkit on them.
    The DoD banned all usb jump drives. They are just now looking at going back to some "known" good drives. I.e. IronKey or some other encrypted (read expensive) jump drives.
    Assuming that you are very paranoid and that your shop time is worth the effort.
    You can set up a "transfer" pc with your anti virus of choice. Then copy the customer files from their jump drive to yours. This machine wouldn't be used for anything buy scanning of drives and moving files.
    But as stated above, you want to make sure that you disable any autorun software. And you want the AV software to scan the USB on insert.
  1. Wishlist for the next drive (describe your dream drive!)
    By Xerxes in forum CNC Machine Related Electronics
    Last Post: 04-01-2012, 10:26 PM
  2. Direct Drive Vs Belt Drive for a Mill/Drill Retrofit?
    By pfeist in forum Uncategorised MetalWorking Machines
    Last Post: 02-13-2012, 09:12 AM
  3. 3 ½ floppy drive to USB flash drive readers
    By scadvice in forum CNC Machine Related Electronics
    Last Post: 08-10-2010, 05:43 PM
  4. CNC Lathe - Servo direct drive or pulley drive?
    By s76tools in forum Uncategorised MetalWorking Machines
    Last Post: 09-06-2009, 05:17 PM
  5. Replies: 3
    Last Post: 07-04-2008, 12:57 AM
