586,043 active members*
3,704 visitors online*
    Aug 2008
    9
    8050 - 8055 file shareing conflictions.
    i am working with 2 fagor cnc centre lathes. 8050 and a newer 8055 controler. it seams as thought the m code functions are arse about. one controler uses m00 m05 to stop the spindle and then pause the program. the other controller uses m05 m00 to stop and pause. is there a way to set the m functions. in the paramater settings maybe?
    Jul 2008
    67
    Quote Originally Posted by beno View Post
    Beno,
    The exact details of what each M-code does is actually set by the Builder/Integrator of the machine and is located within the PLC program.
    I could walk you through it if I had the PLC program in front of me, but in reality, the best thing to do is contact your Machine Builder.... they should have the seperate PLC programs and can easily tell you how to set the one that you want changed..... takes no more than a minute or two.
    good luck !
    Todd
  1. Fagor 8055 DNC communication
    By theartz in forum Fagor Automation
    Last Post: 01-12-2011, 11:13 PM
  2. Error on Fagor 8055
    By carving123 in forum Commercial CNC Wood Routers
    Last Post: 01-18-2010, 02:44 PM
  3. 8055 only accepts pim files?
    By xkadet in forum Fagor Automation
    Last Post: 10-14-2009, 01:46 PM
  4. Fagor 8055 Control
    By ChadK in forum Fagor Automation
    Last Post: 07-01-2009, 10:54 AM
