586,089 active members*
3,767 visitors online*
    Nov 2004
    239
    Gross Positioning Error
    I have a bridgeport intgeract II. I'm getting a gross positioning error lately.
    The z axis servo will buzz and the gear will shake back and forth. Then the machine will quit with that error.
    Resistance in the z axis servo is low compared to the y axis.
    I've taken off the servo and cleaned the carbon deposits from the housing. I checked the brushes and they seem okay. Still plenty of brush left on all 4.
    The commutator had a groove where the brushes run. I couldnt get a good idea of how deep the groove was but I could see a groove. I didn't pull the armature all the way out.
    Any suggestions about troubleshooting this servo?
    The machine is working fine right now but can error out at any time.
    1121
    re
    likely a tach error, have you adjusted the trailing error?
    Nov 2004
    3028
    Is there a letter after the gross positioning error?
    George
    Nov 2004
    239
    The letter was either a B or 8. My monitor is blurry sometimes.
    The problem got worse. The machine errored out and the electrical box started smoking. I found a large black burned spot on the driver board. Now the z axis just dives towards the table and stops when it reaches its travel limit.
    I either need a new driver board for the z axis or try to replace the bad components.
  1. Gross Position Error
    By Mike Conboy in forum Bridgeport / Hardinge Mills
    Last Post: 06-15-2009, 09:38 AM
  2. Bridgeport Interact 4-Gross Positioning Error
    By foolmaker in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2009, 10:13 PM
  3. HELP! Gross positioning error
    By crazeekev in forum Bridgeport / Hardinge Mills
    Last Post: 09-09-2008, 04:11 PM
  4. 320 Positioning Error
    By elogicca in forum Gecko Drives
    Last Post: 07-08-2008, 05:33 PM
  5. Bridgeport VMC308 - Gross Position Error
    By mcwmah in forum Community Club House
    Last Post: 11-09-2007, 10:34 PM
