586,114 active members*
3,398 visitors online*
Results 1 to 7 of 7
    Jun 2009
    113
    Secret to plastic?
    So whats the secret to cutting plastic? i'm trying to drill and mill ABS 1/8" plastic and i cant get a clean cut to save my life. I have a 1/8" router bit which chips upwards. I've tried running the machine as fast as it will go, and as slow as it goes and i get virtually the same results, melted plastic. I bought a .062" plastic bit but all it does is melt and jams the bit which ruins my project. I have a router with a 1/4" shank, and i need a 1/8" milling bit ford drilling and side cutting. Any tips?
    How fast can you cut, and do you have variable speed? With small tools, you have to get the chips out of the cut, or they'll melt on the next pass. A blast of compressed air on the cut will help.
    Oct 2005
    2392
    ABS is elastic and if you cut too deep it squeezes around the bit and generates too much heat, and like ger21 said you have to get the chips out of the bit.
    Try making much shallower cuts, and maybe try a 2 flute bit instead of 4 flute. And use a sharp bit, not one that has been used on metals or other materials.
    Dec 2004
    1137
    I had good luck with a 2-flute bit on some .25" ABS sheet. But I recently bought a purposed bit for plastic. It's an Onsrud single O-flute and it works as advertised. Like Ger and Roman pointed out, it's all about the heat you generate when cutting. I was running my spindle way too fast and cutting way too slow.
    Using the chip load calculations I've learned that slower RPM and faster feeds are required for the optimum chip load. If your machine is feed limited, then you can reduce the number of flutes and slow the RPM. I'm not an expert and am only sharing my experience. The plastic is UHMW.
    Chip load = Feed rate / (RPM * # of Cutting Edges)
    Feed rate = RPM * Cutting Edges * Chip load
    RPM = Feed rate / (# of cutting edges * Chip load)
    Example:
    Onsrud gave a chip load of .002
    I had my feed at 26ipm
    Thus my RPM should be 13K RPM
    You can see the results of the new end mill following the guidelines. It's perfect right off the machine. You can see the 2-flute try right. The plastic was "smearing" instead of cutting. That was at 20K RPM and with 2 flutes.
    Bad example:
    Chip load = 26/(20,000 * 2) = .00065 or 67.5% too small
    At 20K RPM I would have had to use a feed of 80ipm to get the recommended chip load
    FWIW,
    Jay
    Dec 2004
    1137
    May 2008
    You need to keep the tool and the work as cool as possable, try air from a vaccumn cleaner or compressed air .
    Run the cutter as slow as possable with a fast feed rate.
    Dec 2004
    1316
    Personally I cut with 1/8" (.125") or larger upcut spirals 20 to 25K rpm and never had a problem with melting at about 40 inches/min. My bits are always very sharp.
    Jason
  1. Can you use ABS plastic to do VF?
    By kustomjs in forum Vacuum forming, Thermoforming etc
    Last Post: 09-08-2011, 01:59 PM
  2. PLASTIC STRAW/PLASTIC EXTRUSION PARTS/T8 TUBE
    By shayla in forum News Announcements
    Last Post: 07-21-2009, 09:35 AM
  3. Name this plastic
    By TMaster in forum Glass, Plastic and Stone
    Last Post: 07-13-2008, 04:58 AM
  4. My Plastic CNC
    By alecu7 in forum Open Source CNC Machine Designs
    Last Post: 11-16-2007, 07:44 PM
