586,043 active members*
3,906 visitors online*
Thread: maho 1000
Results 1 to 10 of 10
    Nov 2007
    25
    maho 1000
    Hi
    Is there anybody who knows reason for DIFFERENTIAL COUNTER OVERFLOW error for MAHO1000 with Phillips 432 control. when we want move the axes,machine give error X04(Differential counter overflow) then hydraulic system turn off, Are there any experience with this faults?
    Sincerely!
    NAYEB
    Dec 2008
    18
    Quote Originally Posted by jalil View Post
    Hi
    Sincerely!
    NAYEB
    Is it the same with all axis, or is it only when you move X-axis? If it´s only are problem with X-axis, i would try to switch the linearscale giver from X-Y & Y-X to see if the problem moves to the Y-axis?
    You can also try to start up the machine and let it warmup for about 20min ore more, before you try to run it? This can help if the linearscale giver is worn? Or just try to clean the scale?
    Good luck!
    Nov 2007
    25
    dear GRUSSE:
    we can't move all axes and for all axes give error X,Y,Z 04 also we cleaned all linearscale but problem not solves.
    best regards,
    JALIL
    Dec 2008
    18
    dear GRUSSE:
    best regards,
    JALIL
    Have you check your machine constants, or try to reload them? What software version do you have on your Maho?
    Nov 2007
    25
    yes we check constant & check all of board except drives and software is 432
    Nov 2007
    25
    Quote Originally Posted by Grusse View Post
    Dear GRUSSE:
    Aug 2008
    Exclamation NEED HELP
    Hi. this is Rajesh.
    for power supply we are using a 3 phase online ups with battery backup having an output of +- 1% of pure sine wave for the last 3 yrs.
    Recently we are facing faliures in one axis card and vector drive.
    what would be the probable causes and what can we do???
    would be thankful for your help.
    Jan 2007
    8
    Verify this ones :
    1. Linearscale and sensor
    2. Transmision Belt from axis
    3. Motor grip
    4. Constants
    Jun 2011
    Does anyone have information on the Philips MeBkopf PE2470. Looking for signal info. and wiring schematic
    Nov 2008
    Re: maho 1000
    Do you receive any piece of information? If yes, please, send me these data.
  1. maho mc 5 hs
    By ihavenofish in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 04-16-2014, 04:40 AM
  2. Maho MH 800 P
    By dolmar166 in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 11-22-2013, 12:12 PM
  3. Maho 500C and Maho 500 E2
    By F45CNC in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-10-2013, 10:39 PM
  4. MAHO 1000 Z axies Vibration
    By jalil in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-13-2012, 07:45 AM
  5. need post for maho 1000
    By anilam in forum PowerMILL
    Last Post: 09-21-2011, 02:03 AM
