when I home (zero return) the lathe is the tool disk supposed to index? The manual mentions the turret will "initialize" at startup but I have yet to see it rotate when zeroing the machine. The disk is 180 degrees off from the tool called out in MDI , when I pull the tool setter into place it shows the same tool I have called out but the tool # I have called out is on the other side of the disk
