Hi all
Seem to encountered a problem.. Recently re loaded my PCM Parameters..
Everything is up and running.. What I am noticing is that im not engaged when I run Inches Per Revolution.. On the "check screen" it shows running say .006 IPM, but I can over ride the feed and that shows in FPM.. Bottom line one knows when they are engaged properly because you can override the spindle and the feed will slow down or speed up in relation..
I appreciate you comments..
Chips
