586,401 active members*
2,873 visitors online*
    Jan 2010
    How do I activate the HPCC???
    We just put in a 1999 Mori seiki vertical cnc, It has the fanuc 18i controller on it. I want to use this mill for hi speed 3d finishing and can't for the life of me figure out how to utilize the HPCC. The fanuc book isn't helpful and I have tried searching for an answer. can someone please shed some light on how to make it work?
    Jul 2005
    30
    this is how we start the hpcc on our 18I control
    (TOOL_TYPE : END MILL)
    G5P0
    G91G28Z0.
    G90G49
    G5P10000
    M01
    N1T1
    M06
    T2
    S9580M03
    G0G90X-1.0478Y-.1975M08
    G43Z.1H1
    G1Z.0025F65.
    Feb 2011
    Hpcc is actually an option to turn it on you have to contact fanuc. If you habe the option G5P10000 turns it off and G5P0 cancels it
    Jul 2005
    380
    Quote Originally Posted by Jhil66-3 View Post
    Most correct! You first have to determine if the machine actually HAS the option. This can easily be done by trying to activate it as others have said here. If you get a "no option" or "no such command" alarm you don't have the option and need to contact fanuc to install it.
    Fanuc is good about doing this, but be forewarned that this option entails extra hardware in the cnc and may be expensive. Get a quote first.
  1. Activate editing expansion for 21M
    By edufer1 in forum Fanuc
    Last Post: 06-11-2008, 10:47 AM
  2. Hotkey to activate plugin?
    By bigz1 in forum Screen Layouts, Post Processors & Misc
    Last Post: 04-24-2008, 07:19 PM
  3. Aicc/hpcc Vs Hsm (non Fanuc)
    By highspeedmike in forum Hard / High Speed Machining
    Last Post: 08-24-2007, 01:49 AM
  4. AICC HPCC Help
    By figeacaero in forum Hard / High Speed Machining
    Last Post: 06-15-2007, 07:22 AM
  5. Activating HPCC in a sub-routine?
    By Dawson in forum Daewoo/Doosan
    Last Post: 03-18-2006, 09:04 PM
