586,094 active members*
4,248 visitors online*
IndustryArena Forum > CAM Software > Mastercam > using mastercam to engrave
    Jul 2006
    28
    im using mastercam x to add text to a part. everytime i try to verify i dont get anything. can anybody help
    Feb 2006
    992
    I'm not sure since I don't see the verify. How big the tool?
    The best way to learn is trial error.
    Jul 2006
    297
    the majority of the time when i can not see a tool during backplot it is in the design of the tool or a parameter im asking it to do that wont calculate.
    2007 Haas TMP-1 Microscribe MX-5 Mastercam X4 Mill Level 3 Surfaces,Solids Seagate 2 tb hard drive AMD 64x2 8gig ram windows ultimate 7 64bit Geoforce 8800 GTX
    Jan 2010
    34
    if you don't see anything in verify than check your toolpath parameters. you may be above your plane which will not show you any results in verify
    Aug 2008
    64
    A couple things to check and/or try.
    1. Check your stock setup to make sure it is correct.
    2. Check your planes for the operation(s) to make sure they are correct.
    3. Check to see if you have Z Stock to leave added.
    4. Try changing the depth of cut to something ridiculous to see if you get any results.
    I'm guessing it's one of the above.
  1. Need help bad, How do I engrave text
    By 2Bits in forum Dolphin CAD/CAM
    Last Post: 03-11-2009, 03:40 AM
  2. cut and engrave at which speed?
    By zaheer0047 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-08-2009, 06:59 AM
  3. how to engrave
    By cob in forum Mastercam
    Last Post: 10-17-2008, 08:51 PM
  4. WHAT THE BEST METAL TO ENGRAVE IN?
    By hillco148 in forum MetalWork Discussion
    Last Post: 07-15-2008, 08:45 AM
