586,096 active members*
3,718 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > DFX is not imported correctly...
Results 1 to 12 of 12
    Oct 2004
    16
    I am new for CNC and CAD...
    I chose DesignCAD 3D Ver. 14 --> MeshCAM -->TurboCNC.
    I created sample CAD and exported as DFX file. (Ver. 14).
    But as you see, MeshCAM retrieved only one polygon.
    Is there any way to make this set work?
    What's wrong? DesignCAD export funtionality or simply the DFX file is not compatible with MeshCAM ?
    Help me...
    Attached Files Attached Files
    66
    Meshcam doesn't support dxf files,,, But it will do stl files. If you can draw solids in designcad, than export as a stl file, Meshcam will work.
    66
    Unzip this,,,, it was your file convertedt ot a solid in Acad 14.1, and then exported as a stl file. it will work in meshcam.
    Apr 2003
    178
    If you send me the file I'd be happy to look at it but in general DXF files are fine if you only output 3dFaces- meshes and 2d elements cannot be read by MeshCAM.
    Robert
    Try exploding before you save as .dxf. Your drawing contains meshes, which are really just a series of 3D faces. Usually exploding will work. It does in AutoCAD. THis is what you should end up with.
    Robert. Any chances of adding Mesh support for .dxf import? It would probably eliminate the user having to explode meshes all the time.
    Oct 2004
    16
    Quote Originally Posted by robgrz
    Robert
    I have already attached the DFX file in my first one.
    Do I have to use "AccuTrans 3D" to convert from DFX which is not compatible with MeshCAM to STL?
    As my previous post said, try exploding before you export as .dxf. It should work.
    Are you creating the object with solids in DesignCAD?
    Oct 2004
    16
    I believe so.
    That's probably why the exploding doesnt work. What other file types can you export and import? Can you export .3ds, maybe, and import it back in?
    Nov 2009
    64
    [QUOTE = ger21; 75080] Robert. Todas as possibilidades de adicionar suporte para Mesh. Importação DXF? Provavelmente, seria eliminar o usuário tenha que explodir malhas em todo o tempo. [/ QUOTE]
    a amigo
    voce pode me ajudar a achar um modelo de relogio de parede?
    qualquer modelo.
    grata
    celia Brasil
  1. Dinosaur skeleton, and other models, DXF files.
    By ynneb in forum WoodWorking Topics
    Last Post: 05-12-2016, 02:39 PM
  2. Zeroing imported parts
    By an0n in forum Mastercam
    Last Post: 01-10-2007, 08:13 PM
  3. converting to dfx
    By qsacracer in forum G-Code Programing
    Last Post: 04-26-2005, 09:43 PM
  4. Mechanical Dektop 2004 dfx error
    By fantasy2 in forum Autodesk
    Last Post: 02-05-2005, 02:39 PM
  5. imported rotary tables
    By vacpress in forum Uncategorised MetalWorking Machines
    Last Post: 04-07-2004, 04:03 AM
