586,052 active members*
4,163 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Interfacing 3 Position Rotary Switch with Cycle Jog Step Function
    Jul 2007
    675
    Red face Interfacing 3 Position Rotary Switch with Cycle Jog Step Function
    All,
    I building a router console and wanted to control Mach3's cycle jog step function (1.000, 0.1000, 0.0100, etc) with a multi-position rotary switch. All of my switches are interfaced through a Pokey55T keyboard emulator. I've seen this done in many home brew consoles, but just can't figure out how to wire it so Mach reads each position as a different resolution set.
    Thanks in advance
    I may be wrong, but i think each terminal on the 3 position switch goes to it's own input pin.
    If so, use the macropump to check the status of the 3 inputs, and assign the correct value to the DRO based on the pins status.
    I use a button on my custom screen that uses a macro to switch between 5 increments, and has a shortcut key assigned to it.
  1. new rotary table for its special industrial function
    By sindychen in forum News Announcements
    Last Post: 10-25-2010, 09:35 AM
  2. Home position proximity switch
    By scrambled in forum CNC Machine Related Electronics
    Last Post: 02-25-2009, 07:13 PM
  3. 4 Position Rotary Switch
    By Shanghyd in forum CNC Machine Related Electronics
    Last Post: 04-07-2008, 04:39 AM
  4. M function feed hold tell switch trips?
    By D.D.Machine in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-28-2007, 06:34 PM
  5. Home switch position
    By MrBean in forum DIY CNC Router Table Machines
    Last Post: 12-17-2004, 01:00 AM
