586,069 active members*
3,629 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Didn't let the magic blue smoke out yet.....
Results 1 to 8 of 8
    Oct 2003
    530
    I found these sitting on top of the main transformer in the rear cabinet of my 94 VMC15.
    http://i445.photobucket.com/albums/q...c15sdparts.jpg
    Any ideas where they go?
    I found the brown cap inside the spindle drive. It's a baldor vector drive, but it's an older one probably the original. I was in there changing a blown fuse.
    900
    My IT won't let me access any photobucket images. If you can provide a different medium, I'll have a look for you!
    Neal
    Jan 2007
    1389
    Oh I made a post about this a long while ago.
    I forget the name of them, but was told there not really needed ( which I think is Bull****) Fadal didnt tell me they werent needed. the company I bought my fadal through did. I needed a new drive anyway.
    I'll screen shot the pic for you neal
    Let me see if I can find the post. They typically fall out during shipping. Neal you will know what they are. there about the size of a half dollar and they come on the baldor drives I think there is 3 or 4 of them
    Jan 2007
    1389
    heres the screen shot neal,
    The cap you need for sure, I will snap a pic of where those other piece go if you need it.
    Jan 2007
    1389
    heres my post from a while ago.
    they are Called MOV's
    http://www.cnczone.com/forums/showpo...48&postcount=6
    Oh yeah one other thing, Call fadal they are very good and will guide you through the checking part step by step.. The 9volt battery test will blow your mind
    900
    DELW--
    The red circular pieces are broken off capacitors from the 1170 surge supressor board. Check this board out and if it is damaged then replace it ASAP.
    The darker cylinder I can't make out enough detail to identify it.
    Neal
    Oct 2003
    530
    The brown cylinder is a capacitor with 2200uf and 16v marked on the side. I see a few in the drive, and I even see a spot where it looked like one broke off. I found this inside the drive.
    Where is the 1170 board, is it inside the drive? I found the red things on the transformer under the drive. But they could have bounced out of the drive when the machine was being moved.
    Jul 2009
    317
    those are inside of the old Baldor Sweos;they brake do to overheath; must of the time still good, you can solder'm back
  1. Confused about magic smoke event..
    By skullworks in forum Gecko Drives
    Last Post: 09-07-2009, 08:43 PM
  2. Lathemaster ZAY Looses Magic Smoke in Motor
    By bill south in forum Benchtop Machines
    Last Post: 11-21-2007, 03:28 AM
  3. Replies: 8
    Last Post: 06-24-2007, 03:51 AM
  4. Replies: 2
    Last Post: 08-09-2006, 09:07 PM
  5. Need to refil the magic smoke
    By runnoahrun in forum CNC Machine Related Electronics
    Last Post: 12-01-2005, 06:20 AM
