I have had no problems with the "lovehappyshopping" shop. I have not bought anything from the other one. The units appear to be the same.
If and when you do buy one, don't forget to read the threads on how to set them up properly as you won't get much info from the makers.
If you want to control them by computer then you will also need and analogue to digital converter which can be bought from CNC4PC and is fairly easy to set up. I think Bob has fixed the instructions making it easier.
Get it here. http://www.cnc4pc.com/Store/osc/prod...products_id=58
I have been using mine for the past few months and it's great and nice and quiet and pretty smooth in operation. I bought the 1.5 Kw air cooled spindle and it runs cool to touch after a few hours of running, maybe slightly warm.
The only suggestion I would make is they you ask them to supply the collet nut with the proper collet release type of nut. Mine didn't have one and it was difficult to change the cutter as it would lock pretty tightly on the ER11 collet.
I bought 2 from ctctoolseller on eBay pretty cheaply ($20 aud).
Have fun. I am going to buy another one at a later date as I think they are worth it.
regards
Rich.
I am not completely useless.......I can always serve as a BAD example.
