586,080 active members*
3,616 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > DNC-B to use drip feed
    Jan 2010
    Hello, we have Okuma MC60HB 5-Axis machining centers with the OSP U100M-H Controls. We have the DNC-B option and we are trying to get a drip feed program to run. We have currently been unable to get the program to run. I think it may be some parameter settings that need set possibly but our programming and maintenance departments have been unable to solve. We are utilizing FactoryNet DNC but we have never before attempted to drip feed a program. Our bubble memory is too small. Has anyone been through the drip feed problem on these machines and solved it? We need a solution ASAP. Thanks
    Mar 2009
    1982
    have You two separate RS232 connectors (DB-25)?
    Jan 2010
    RS232 Ports
    Yes We have 2 RS232 Ports. One is labeled CHO & the other is DNC and it also has written RS232-C I/F.
    Jun 2008
    372
    You should be using the DNC connector
    Turn both buffer and transfer switchs on, Then restart machine.
  1. drip feed
    By kirby in forum Fanuc
    Last Post: 11-29-2009, 03:04 AM
  2. Drip feed, DNC?
    By Greg_B in forum Mastercam
    Last Post: 05-20-2009, 05:31 AM
  3. Drip Feed
    Last Post: 10-20-2008, 03:21 PM
  4. Drip feed?
    By kotten1 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-08-2008, 08:44 AM
  5. BMC-20 w/Max II drip feed......
    By GPena in forum HURCO
    Last Post: 10-31-2007, 06:37 PM
