586,108 active members*
3,013 visitors online*
    Apr 2007
    148
    Invar turning
    I have a project coming up that is going to require me to turn 1/4-28 invar screws from bar stock. Any ideas on feed and speed, I was thinking 130SFM at .002-.003" per rev. Any tips on threading, I will be using full profile laydown inserts, I was planning to use G76 with 5 passes. Any tips and tricks would be greatly appreciated. Thanks in advance to all that reply.
    Apr 2007
    148
    Just a quick bump and a progress report on this issue. I used the recommended speeds and feeds out of the book for this material and turning it was fine. I did run into a major issue with chattering while threading. The threads looked terrible. I played around with the threading portion, ie G76 and discovered that using an A55 modified infeed produced excellent results. We even turned some 4-40 screws out of invar and they looked great. Just thought I'd give an update in case anyone else runs into this issue.
  1. Invar 36
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 12-10-2009, 01:55 PM
  2. Turning
    By camtd in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-01-2007, 06:40 PM
  3. Machining Invar 36
    By Kosta1234 in forum MetalWork Discussion
    Last Post: 02-25-2005, 05:03 AM
  4. Machining Invar 36
    By Kosta1234 in forum Hard / High Speed Machining
    Last Post: 02-17-2005, 11:01 PM
  5. Invar 36 Invar 36fm
    By Rekd in forum Hard / High Speed Machining
    Last Post: 10-17-2003, 12:01 AM
