586,112 active members*
2,999 visitors online*
Results 1 to 10 of 10
    Aug 2008
    45
    Question Tapping Question?
    I just did the Spindle Drive Upgrade to my machine, What a difference that made! I plan on getting the Tension/Compression Tapping Head because I have a bunch of 8-32 and 1/4-20 holes to tap in 6061 aluminum. My question is who makes good taps for this and what lube works best? I saw somewhere in the something about lube, but I can't find it. Any thoughts on a good way to go about this or things to watch out for would also be appreciated.
    Thanks!
    Larry O
    Sep 2009
    318
    I use tapping fluid as I dont want to run the coolant just to tap a part.
    I bought some taps like this http://www1.mscdirect.com/CGI/NNSRIT?PMAKA=09223637 and they seem to work good and they snap into place in the holders nicely.
    Mar 2006
    58
    OSG Makes some wicked taps. They're pricey, but a great product. You can buy them from MSC or your local supplier. I would recommend the spiral flute for blind holes and the spiral point for thru holes.
    Aug 2008
    45
    Thanks Guys!
    I just ordered some OSG taps, They looked like good quality to me. I'll let you know..
    Larry O
    Jul 2007
    1602
    Since you are tapping aluminum, you might want to look at thread forming taps.
    bob
    Sep 2009
    318
    All I ever do is tap aluminum. Can you explain the benefits/difference in using thread forming taps?
    Jul 2007
    1602
    A thread forming tap displaces the material rather than cutting it therefore you don't have any chip clearance problems. The threads are also supposed to be stronger. You do have to drill a slightly larger hole though since you are not removing any material.
    Here is a bit of a pitch by one manufacturer. If you do a forum search on thread forming tap you will find more info here as well.
    http://www.precisiontwistdrill.com/t..._prod_taps.asp
    bob
    Jan 2007
    1332
    I have tapped 10s of thousands of 4-40 blind holes in 6061-T6 using Balax forming taps. http://www.balax.com/forming.html With forming taps there are no chips so they work especially well in blind holes. I use Relton A9 tapping fluid with excellent results. Here is a video tapping 2-56 blind holes using a balax forming tap on the Tormach. http://s72.photobucket.com/albums/i1...6Procunier.flv
    Don Clement
    Sep 2009
    318
    Thanks for the info.. I take it they will work fine with the tension/compression tapping head? Would I use the same code as a normal tap?
    Jan 2007
    1332
    Quote Originally Posted by compunerdy View Post
    I haven't tried forming taps with my Tormach tension-compression heads yet because most of my tapping is ¼”/M6 or less blind holes and the Procunier tap head works extremely well for blind small holes less than ¼”/M6. in addition the Procunier tap head will stop within a 1/3 revolution for blind holes. I use the same program code for the forming tap as cutting taps and peck cycle is not necessary when using a forming tap because there are no chips produced. Be aware that forming taps require a larger drill size than cutting taps. Material also affects drill size with forming taps so it is best to experiment using the tap manufacturer recommendations as a starting point.
    Don
  1. Another rigid tapping question?
    By crash80 in forum Fanuc
    Last Post: 08-06-2008, 09:55 PM
  2. VF1-4 Tapping Question
    By Greg 24 in forum Haas Mills
    Last Post: 06-20-2007, 04:20 AM
  3. G63 Tapping Mode question
    By Al_The_Man in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-11-2007, 05:09 PM
  4. tapping head vs hand/cordless tapping machine....
    By InspirationTool in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2005, 02:10 AM
  5. Tapping aluminum question
    By cnc2k in forum MetalWork Discussion
    Last Post: 02-28-2005, 04:15 AM
