586,052 active members*
3,894 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 18i-TB with Manual Guide i problem
Results 1 to 9 of 9
    Aug 2004
    218
    Hello
    I recently bought a 2006 Doosan 2000sy with a Fanuc 18i-TB control. When the control is turned on it will display "loading graphics", then display "loading manual guide i"
    Once it has finished loading control is now on, I now can't find the manual guide i anywhere on the display. When I press the custom button it is just not there. I have attached pic's of the special settings parameters, would some of you more experianced gentlemen take alook at them an tell me if this control is capable of Manual Guide i an how to get it going.
    Thank you for your time.
    Attached Thumbnails Attached Thumbnails Fanuc 18i-TB 10001.jpg   Fanuc 18i-TB 20001.jpg   Fanuc 18i-TB 30001.jpg   Fanuc 18i-TB 40001.jpg
    2932
    What is the serial number of the machine?
    Aug 2004
    218
    S/N is P200SY0764
    Aug 2004
    218
    here are afew pic's of the system check page.
    Attached Thumbnails Attached Thumbnails DSC04609.jpg   DSC04611.jpg   DSC04612.jpg   DSC04615.jpg
    Your machine definatly has EzGuide i installed as an option
    When you push custom you woul dnormally get the option in the right most softkey to select EzGuide or NC Prog. Depending upon your preference you can choose either
    Then when you push the PROG key on the Fanuc MDI panel it will either be in e MGi/EzGuide or NC Prog screen
    Else I would sugest it has not been setup correctly
    The best course of action would be to ask the dealer you purchased it from to contact Doosan
    Check Keep Relay
    K10.5
    K51.5
    Check Parameters
    14700#7= ?
    14794 = ?
    *~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
    *__________If you feel inclined to pay for the support you receive__________*
    *_______Please give to charity https://www.oxfam.org.au/get-involved/_______*
    Mar 2006
    167
    MGi is sometimes set to load with the graphics button. Which button is used is changed by parameter setting, but I can not recall number at moment. I have seen it configured to load on Custom, Graphics, and Blank, and all of these on Doosan machines.
    As MM said...check 14700#7, and 14794. Also, if 14794 all 0, then check 14795.
    2932
    If I'm not mistaken, Doosan brought in these machines with Manual Guide-i loaded, but it had to be turned on ($$$) to function. They offered EZ Guide-i I ($$$), their own version, with additional screens, and tailored to their machines.
    That vintage machine was right at the changeover from having to have EZ Guide-i installed in the field to having it preloaded at the factory, and only having to activate it in the field.
    Here's the section on MG-i from the Fanuc 16/18i-T Descriptions Manual. The full manual PDF is about 12MB.
    Attached Files Attached Files
    Aug 2004
    218
    Thank you so much for all your help guys
    Mike Roy in Canada
    Aug 2004
    218
    I still need help guys, this problem just won't give up!!!.
  1. Fanuc NC GUIDE
    By sinha_nsit in forum Fanuc
    Last Post: 12-18-2023, 09:50 AM
  2. Opinion Manual Guide i
    By CBNDude in forum Fanuc
    Last Post: 10-13-2010, 06:02 PM
  3. Manual guide i?
    By JDenyer232 in forum Fanuc
    Last Post: 11-07-2007, 03:16 PM
  4. manual guide
    By vihgis_cnc in forum MetalWork Discussion
    Last Post: 09-16-2005, 07:22 PM
