586,909 active members*
3,237 visitors online*
    Jun 2005
    1436
    "Test this axis/Run", and a limit switch
    When using the "Test this axis" window, and the "Run" command, does operating the limit switch stop the motor running ?
    In other words can I use this to find the correct settings for the limit switch for each axis ?
    At the moment, it has no effect, and I don't know if it's because the setting in the parallel port window is incorrect, or if I have another problem elsewhere.
    John
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
    Jun 2005
    1436
    I've set up just the X axis motor connected to the controller, and gone through every possible setting for pin 11, my X limit input, both normal and inverted.
    When I use the "Run" command in the "Test this Axis" window, none of the settings produced any change when the N/C limit switch was pressed. The motor continued to run.
    Jun 2005
    1436
    Now added the Y and Z motors, with a N/C limit switch each, to the controller.
    No change is apparent in that the controller ignores the X and Z limit switches, but requires the Y limit to be open for that one to operate.
    Jun 2005
    1436
    All is solved.
    The contoller needs an inverted enable signal on pin one for the Y axis to behave like the other two axis.
    "Test the axis " I'm informed, doesn't react to the limit switches, so I'll have to go back to a real set up to locate and test them.
  1. "Test this axis" - unexpected result
    By greybeard in forum LinuxCNC (formerly EMC2)
    Last Post: 03-29-2022, 10:26 AM
  2. My "Crazy" high speed spindle test
    By SScnc in forum Benchtop Machines
    Last Post: 04-21-2009, 01:16 PM
  3. Interesting "Gross Position ERROR A" with no limit detection
    By A.A in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2009, 09:45 PM
  4. TM-1...Need to disable "safety switch"
    By jwknow in forum Haas Mills
    Last Post: 01-16-2008, 05:52 AM
  5. Replies: 0
    Last Post: 08-05-2007, 12:11 AM
